Vero V remote not pairing or working
@darwindesign, thank you for the explanation.
Hi again, sorry for the delay. Part of it was no doubt a reaction to my first test with one of my better USB power meters. I plugged it into the USB2 port - power. I plugged it into the USB3 port - also power. I unplugged it, went off to find my USB resistive load - which I tested on a charger to check what the current draws were (1, 2 or 3A - so too much to plug into the Vero I assume) - went back to the Vero and plugged just the meter into USB3 again - no power! Did I just not plug it in far enough…??? I went back half an hour later with my best meter, power on both ports. Needless to say I was confused - it didn’t feel likely that I suddenly forgot how to properly plug in a USB device. However - on testing again now - it seems that jiggling the power meter in the USB3 slot is killing the power, so presumably some mechanical damage there. Would opening it up and looking at it under a microscope be appropriate, and resoldering the USB3 connections?
Thanks @thechrisgregory for your suggestion - I confirm that going to settings/system/input/peripherals only displayed CEC Adapter. (logs from startup here: https://paste.osmc.tv/ajehorejem)
osmc-remote-lircd was in brighter white text than all the other entries in settings/My OSMC/remotes, but I followed instructions, confirming it, and rebooted. Alas, no change - remote still doesn’t work, and it’s still not listed under settings/system/input/peripherals. Just checking, on that settings/My OSMC/remotes page, the “Disable RC6” appears to be enabled - I presume this is as intended.
I feel like my issue may also have appeared after a recent update. I hadn’t used the device for a while, came to use it, accepted an update presumably via the remote - but I’m unsure exactly how soon afterwards the remote didn’t work, so it could be unrelated.
Anyway - if repairing/resoldering the USB3 port is a good place to start, are there screws under the rubber feet - and any guides for disassembly? Thanks!
I’ve experimented a little further with the ‘disappearing OSMC RF Remote’ problem. Turns out that a full power cycle is required after a staging repo upgrade to make it re-appear.
After upgrading to vero564-image-4.9.269-78-osmc:arm64 from vero564-image-4.9.269-77-osmc:arm64 (staging repo, Dolby Vision Test builds) I once again noticed my OSMC RF remote was not working, and the vero was not responding to keypresses.
I was able to use my LG TV RF remote to navigate through the Vero-V menus. This time I tried a ‘soft’ reboot (power/reboot) and the remote still did not appear under settings/system/input/peripherals .
Then I tried a full power cycle (power/power off system), disconnected/reconnected the power supply,
and allowed the Vero-V to ‘cold’ boot.
Following this ‘cold restart’ (power cycle) the OSMC RF remote re-appeared under settings/system/input/peripherals along wih the CEC Adapter, and worked as expected.
There are some logs here - https://paste.osmc.tv/owivuwulod
Your logs show that the receiver is being detected.
… but it wasn’t detected after the ‘soft’ reboot …
So if you reboot the receiver is always undetected until a cold start?
I think we might need to split this thread out as other remote issues have since been solved
I think I’m having the same issue as noted on this thread originally. Logs https://paste.osmc.tv/jebigedato
The remote was working fine and stopped responding the other day. LED is flashing away, fresh battery installed. Held the home/ok combo but it never repaired. The light would turn off eventually. Please help!
I suggest contacting support@osmc.tv with some details.
Emailed 3 days ago, with no response :confused:
Sorry for the delays. I am a bit behind on emails but should be up to date with them in full by Saturday latest.
I did reply to your email about an hour ago. Let me know if you’ve received it.
Yup, cheers for the reply
I’m having the same issue as some users here. My remote stopped working after a recent update. I’ve tried all the trouble shooting methods, even installing a fresh OS.
My USB 3.0 port does not work, but my USB 2.0 port works, and is the only way I can operate the Vero V with a keyboard.
Here is my log: https://paste.osmc.tv/azipajakid
I’ve tried emailing support on Oct 10th, 15th, and 23rd with no response. Anything else I can try?
If you haven’t got a response from me now please let me know the ticket number
Thank you Sam. I did get an email, so we should be good.
Brilliant, apologies for the delays.
Just wanted to add my experience. The remote not working, the cold, soft, hard reboots had no effect. the unplugging had no effect. I was about to open the unit but I checked logs first.
saw some events that google was referring to power supply issues
Finally I unplugged power supply from the wall to inspect it for a 20sec, plugged back in and everything worked again. I would call it a coincidence if I didn’t already do 6 hard resets prior
[ 4.769265] systemd-journald[2388]: Received client request to flush runtime journal.
[ 4.803805] ammvdec_mpeg12 module init
[ 4.873973] ammvdec_h264 module init
[ 4.895349] ammvdec_mpeg4_driver_init_module
[ 4.931417] usb 1-1.2: new full-speed USB device number 6 using xhci-hcd
[ 4.932134] usb 1-1-port2: cannot reset (err = -71)
[ 4.932234] usb 1-1-port2: cannot reset (err = -71)
[ 4.937190] amvdec_av1 module init
[ 5.048893] decoder registered as /dev/video26
[ 5.049811] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 5.059597] Registered IR keymap rc-empty
[ 5.059750] input: meson-ir as /devices/platform/fe084040.meson-ir/rc/rc0/input5
[ 5.059902] rc rc0: meson-ir as /devices/platform/fe084040.meson-ir/rc/rc0
[ 5.060327] meson-ir fe084040.meson-ir: receiver initialized
[ 5.060798] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 5.068853] lirc_dev: IR Remote Control driver registered, major 490
[ 5.072032] rc rc0: lirc_dev: driver ir-lirc-codec (meson-ir) registered at minor = 0
[ 5.072038] IR LIRC bridge handler initialized
[ 5.151518] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[ 5.151619] usb 1-1-port2: cannot reset (err = -71)
[ 5.151721] usb 1-1-port2: cannot reset (err = -71)
[ 5.151724] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 5.191505] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[ 5.191618] usb 1-1-port2: cannot reset (err = -71)
[ 5.191714] usb 1-1-port2: cannot reset (err = -71)
[ 5.341397] lcd vlock_en=1, vlock_mode=0x4
[ 5.361368] meson-mmc: [sdio_notify] finish
[ 5.362695] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 5.362700] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[ 5.362730] meson-mmc: meson_mmc_irq_thread_v3 656 sdio: cmd:52
[ 5.364238] meson-mmc: sdio: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 5.364242] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8
[ 5.364250] meson-mmc: meson_mmc_irq_thread_v3 656 sdio: cmd:52
[ 5.368792] meson-mmc: sdio: resp_timeout,vstat:0x9dff0800,virqc:3fff
[ 5.368795] meson-mmc: sdio: err: wait for desc write back, bus_fsm:0x7
[ 5.368802] meson-mmc: meson_mmc_irq_thread_v3 656 sdio: cmd:8
[ 5.369377] meson-aml-mmc fe088000.sdio: card claims to support voltages below defined range
[ 5.421489] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[ 5.421620] usb 1-1-port2: cannot reset (err = -71)
[ 5.421623] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 5.421730] usb 1-1-port2: attempt power cycle
[ 5.430795] meson-mmc: sdio: clk 166666664 tuning start
[ 5.432096] cectx fe044000.aocec: bad iniator with self 0x0
[ 5.436123] meson-mmc: sdio: adj_win: < 0 1 2 3 5 >
[ 5.436129] meson-mmc: step:4, delay1:0x104104, delay2:0x4000000
[ 5.440132] meson-mmc: sdio: adj_win: < 0 1 2 3 5 >
[ 5.440136] meson-mmc: step:8, delay1:0x208208, delay2:0x8000000
[ 5.443410] meson-mmc: sdio: adj_win: < 0 1 2 3 >
[ 5.443416] meson-mmc: left:4, right:0, mid:5, size:5
[ 5.443419] meson-mmc: step:0, delay1:0x0, delay2:0x0
[ 5.443423] meson-mmc: sdio: sd_emmc_regs->gclock=0x10000246,sd_emmc_regs->gadjust=0x12000
[ 5.444478] sdio: new ultra high speed SDR104 SDIO card at address 0001
[ 5.444481] sdio: clock 166666664, 4-bit-bus-width
[ 5.444714] meson-mmc: [sdio_reinit] finish
[ 5.575962] cectx fe044000.aocec: bad iniator with self 0x0
[ 5.735719] cectx fe044000.aocec: bad iniator with self 0x0
[ 5.761545] usb 1-1-port2: cannot reset (err = -71)
[ 5.761623] usb 1-1-port2: cannot reset (err = -71)
[ 5.761717] usb 1-1-port2: cannot reset (err = -71)
[ 5.761811] usb 1-1-port2: cannot reset (err = -71)
[ 5.906191] cectx fe044000.aocec: bad iniator with self 0x0
[ 5.981697] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[ 5.981704] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6.011540] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[ 6.011627] usb 1-1-port2: cannot reset (err = -71)
[ 6.011724] usb 1-1-port2: cannot reset (err = -71)
[ 6.011902] usb 1-1-port2: cannot reset (err = -71)
etc etc
happened again and I tried the same steps as before. I let the unit cool off, unplugged psu from wall, from unit, changed remote battery, etc. The coincidence or not is when the unit was powered back on without HDMI
I ran a before and after dmesg via SSH so I could monitor if it found the remote
here’s the diff from windows fc
Comparing files before.txt and AFTER.TXT
***** before.txt
hdmitx: hdmitx_uboot_audio_en[709] data = 0x1f
hdmitx: [load_edid_data] failed to open file: |/lib/firmware/edid|
vout sys: aml_vs_probe OK
***** AFTER.TXT
hdmitx: system: irq 4 0
EARC fe333800.earc: HDMITX cable is plugout
hdmitx: system: plugout
hdmitx: hdmitx_set_drm_pkt: disable drm pkt
hdmitx: hdmitx_set_hdr10plus_pkt: null vsif
[RX]-up_phy_addr = 0
hdmitx: system: cann’t get valid mode
***** before.txt
meson-mmc: gpio_cd = 1c1
hdmitx: edid: EDID Parser:
hdmitx: hdmitx: vic 768 added to vesa modes
hdmitx: hdmitx: vic 770 added to vesa modes
hdmitx: hdmitx: vic 774 added to vesa modes
[RX]-up_phy_addr = 51
hdmitx: Edid_ParsingVendSpec:ieeeoui=0xd046,len=11
hdmitx: v1 VSVDB: len=11, sup_2160p60hz=1, low_latency=1
hdmitx: hdmitx: vic 780 added to vesa modes
hdmitx: edid: get dtd0 vic: 97
hdmitx: edid: get dtd1 vic: 16
hdmitx: hdmitx: get PMT vic: 97
hdmitx: edid: find IEEEOUT
hdmitx: edid: blk0 raw data
00 ff ff ff ff ff ff 00 11 ee 56 00 01 01 01 01
00 1b 01 03 80 a0 5a 78 0a ee 91 a3 54 4c 99 26
0f 50 54 a1 08 00 31 40 45 40 61 40 71 40 81 80
01 01 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58
8a 00 40 84 63 00 00 1e 02 3a 80 18 71 38 2d 40
58 2c 45 00 40 84 63 00 00 1e 00 00 00 fc 00 44
45 4e 4f 4e 2d 41 56 52 48 44 0a 20 00 00 00 fd
00 3a 79 1e 88 3c 00 0a 20 20 20 20 20 20 01 a2
hdmitx: edid: blk1 raw data
02 03 79 f1 5f 61 60 10 1f 66 65 04 13 05 14 03
02 12 20 21 22 15 01 5d 5e 5f 62 63 64 3f 40 0e
23 0f 24 1e 38 0f 7f 07 3d 1e c0 15 07 50 5f 7e
03 57 06 03 67 7e 03 4d 02 00 5f 7e 01 83 5f 00
00 6e 03 0c 00 15 00 b8 3c 20 00 80 01 02 03 04
67 d8 5d c4 01 78 80 03 e2 0f 33 e3 06 0d 01 eb
01 46 d0 00 26 18 03 91 82 69 7c e3 05 c0 00 e2
00 cf e6 11 46 d0 00 70 00 00 00 00 00 00 00 30
hdmitx: system: update rx hdr info d
hdmitx: hdmitx: get vic 353 cscd
hdmitx: hdmitx: mode name 3840x2160p60hz420
hdmitx: hdmitx: tmds clock 594
hdmitx: hdmitx: act clock: 297
hdmitx: system: irq 2 0
EARC fe333800.earc: HDMITX cable is plugin
meson-mmc: meson_mmc_probe() : success!
***** AFTER.TXT
***** before.txt
random: fast init done
brd: module loaded
meson-mmc: emmc: adj_win: < 0 2 3 4 >
***** AFTER.TXT
***** before.txt
meson-mmc: step:8, delay1:0x8208208, delay2:0x8008208
loop: module loaded
***** AFTER.TXT
meson-mmc: emmc: adj_win: < 0 1 2 3 4 >
meson-mmc: step:12, delay1:0xc30c30c, delay2:0xc00c30c
meson-mmc: emmc: adj_win: < 0 1 3 4 >
meson-mmc: left:3, right:0, mid:4, size:4
meson-mmc: emmc: sd_emmc_regs->gclock=0x10000245,sd_emmc_regs->gadjust=0x42000
meson-mmc: emmc:use ds type4
meson-mmc: emmc: support driver strength type 4
meson-mmc: emmc: try set sd/emmc to HS400 mode
meson-mmc: aml_sd_emmc_clktest [1609] clktest : 9216, delay_cell: 69, count: 36
meson-mmc: get temperature failed
brd: module loaded
loop: module loaded
***** before.txt
eth%d: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
***** AFTER.TXT
***** before.txt
optee_armtz: initialized driver
value of voltage_tolerance 0
***** AFTER.TXT
***** before.txt
value of gp1_clk_target 0
cpu cpu0: meson_cpufreq_init: CPU 0 initialized
***** AFTER.TXT
***** before.txt
cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1512000 KHz
cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1608000 KHz
meson-mmc: aml_sd_emmc_clktest [1609] clktest : 9204, delay_cell: 71, count: 35
fe07a000.serial: clock gate not found
***** AFTER.TXT
***** before.txt
input: gpio_keypad as /devices/platform/gpio_keypad/input/input0
Enable disable_nonboot_cpus in syscore shutdown.
***** AFTER.TXT
meson-mmc: scan time distance: 155298500 ns
meson-mmc: best_start 0x1, best_size 36, cmd_delay is 0x13
meson-mmc: [tl1_emmc_line_timing], delay1: 0xc30c30c, delay2: 0x1300c30c
***** before.txt
fb: ---------------clear fb0 memory (ptrval)
fb: osd[0] canvas.idx =0x40
***** AFTER.TXT
meson-mmc: ds_sht:18, window:22, intf3:0x412008, clock:0x10120002
meson-mmc: adjust:0x0
emmc: new HS400 MMC card at address 0001
emmc: clock 199999997, 8-bit-bus-width
mmcblk0: emmc:0001 A3A551 28.9 GiB
mmcblk0boot0: emmc:0001 A3A551 partition 1 4.00 MiB
mmcblk0boot1: emmc:0001 A3A551 partition 2 4.00 MiB
mmcblk0rpmb: emmc:0001 A3A551 partition 3 16.0 MiB
meson-mmc: Enter aml_emmc_partition_ops
meson-mmc: [mmc_read_partition_tbl] mmc read partition OK!
meson-mmc: add_emmc_partition
card key: card_blk_probe.
emmc_key_init:493 emmc key lba_start:0x12020,lba_end:0x12422
calc 1026e0affc, store 1026e0affc
do nothing
emmc key: emmc_key_init:519 ok.
meson-mmc: amlmmc_dtb_init: register dtb chardev
***** before.txt
fb: osd[0] out_addr_id =0x1
Console: switching to colour frame buffer device 240x67
meson-mmc: scan time distance: 139356082 ns
meson-mmc: best_start 0x2, best_size 35, cmd_delay is 0x13
fb: set osd0 reverse as NONE
***** AFTER.TXT
meson-mmc: total valid 2
meson-mmc: amlmmc_dtb_init: register dtb chardev OK
meson-mmc: amlmmc_ddr_init: register ddr_parameter chardev
meson-mmc: amlmmc_ddr_init: register ddr parameter chardev OK
meson-mmc: Exit aml_emmc_partition_ops OK.
random: crng init done
***** before.txt
dil:dil_init ok.
rdma_register, rdma_table_addr (ptrval) rdma_table_addr_phy e4058000 reg_buf (ptrval)
rdma_register success, handle 3 table_size 512
***** AFTER.TXT
dil:dil_init ok.
rdma_register, rdma_table_addr 00000000ab12f888 rdma_table_addr_phy e4058000 reg_buf 0000000059a2e453
***** before.txt
Reserved memory: failed to init DMA memory pool at 0x00000000e9000000, size 0 MiB
PPMGRDRV: info: ppmgr_dev major:501
ionvideo-000: V4L2 device registered as video13
***** AFTER.TXT
PPMGRDRV: info: ppmgr_dev major:499
***** before.txt
aml_iomap: read cbus reg 21 error -1
aml_iomap: read cbus reg d1 error -1
***** AFTER.TXT
***** before.txt
vsync_pts_inc 1501 1001/60000
am_vecm: signal type changed
hdmitx: hdmitx_set_drm_pkt: tf=1, cf=1, colormetry=0
aml_vrtc rtc: rtc core: registered aml_vrtc as rtc0
***** AFTER.TXT
***** before.txt
cectx fe044000.aocec: not find ‘arc_port_mask’
do nothing
cectx fe044000.aocec: wakeup_reason:0x0
cectx fe044000.aocec: wakeup_data: 0x0 0x0
***** AFTER.TXT
***** before.txt
hdmitx: system: plugin
asoc-aml-card auge_sound: control 2:0:0:I2SIn CLK:0 is already present
snd_tdm fe330000.audiobus:tdm@1: ASoC: Failed to add I2SIn CLK: -16
***** AFTER.TXT
***** before.txt
spdifout_play_with_zerodata_free, spdif id:0
audio_ddr_mngr: frddr stop success, fifo id 0, regbase:0x70, arb sts:0x40000010
asoc-aml-card auge_sound: dummy ↔ SPDIF-A mapping ok
***** AFTER.TXT
***** before.txt
aml_vrtc rtc: setting system clock to 2026-01-08 00:59:00 UTC (1767833940)
dwc_otg fdd00000.dwc2_a: dwc_otg_driver_probe( (ptrval))
dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: fe03a000, ctrl: 0
***** AFTER.TXT
aml_vrtc rtc: setting system clock to 2020-01-01 00:00:09 UTC (1577836809)
dwc_otg fdd00000.dwc2_a: dwc_otg_driver_probe(0000000083fb157d)
***** before.txt
hdmitx: video: cur_param = param at 0x0a871018 colourdepth 8 colourspace 0
hdmitx: video: pixel freq 148500, tmds clock 148500, MaxClock1 300000, HF_IEEEOUI 0xc45dd8, MaxClock2 600000
hdmitx: hw: div40: 0
hdmitx: system: update physical size: 1600 900
hdmitx: video: auto - get current mode: 1080p60hz vmode_e 0
hdmitx: system: stream colourdepth was 8 in para (ptrval) (1920x1080p60hz)
hdmitx: system: display colourdepth was 8 in cur_param 0x0a871018 (VIC: 16)
hdmitx: video: DV output not enabled
hdmitx: video: hdev->para now = para at 0x0a87cbe8
hdmitx: hdmitx: display colourdepth is 10 in cur_param 0x0a871018 (VIC: 16)
hdmitx: system: Stream colourdepth is 8 in para 0x0a87cbe8 (1920x1080p60hz - VIC: 16)
hdmitx: video: already init VIC = 0 Now VIC = 16
hdmitx: video: params found at 0x0a871018
hdmitx: video: cur_param = param at 0x0a871018 colourdepth 10 colourspace 2
hdmitx: video: pixel freq 148500, tmds clock 185625, MaxClock1 300000, HF_IEEEOUI 0xc45dd8, MaxClock2 600000
hdmitx: frac_rate = 1
hdmitx: config HPLL = 3712500 frac_rate = 1
hdmitx: HPLL: 0xdb00049a
hdmitx: config HPLL done
hdmitx: set_hpll_od3_clk_div[687] div = 8
hdmitx: j = 4 vid_clk_div = 1
***** AFTER.TXT
hdmitx: video: pixel freq 148500, tmds clock 148500, MaxClock1 0, HF_IEEEOUI 0x000000, MaxClock2 0
hdmitx: E: ddc w1b 0x54 0x20 0x00
hdmitx: config HPLL = 5940000 frac_rate = 1
hdmitx: set_hpll_od3_clk_div[687] div = 6
***** before.txt
hdmitx: s-val 2199 h_total 2200
hdmitx: system: irq 80000001 0
hdmitx: set enc for VIC: 16
hdmitx: system: PHY Setting Done
hdmitx: hw: config hdmitx IP vic = 16 cd:5 cs: 2
hdmitx: video: Sink is HDMI device
***** AFTER.TXT
hdmitx: hw: config hdmitx IP vic = 16 cd:4 cs: 0
***** before.txt
hdmitx: hw: hdmitx no channel mask - assume stereo
hdmitx: hw: set audio type 1 channels 1 + 1
hdmitx: hw: tx_aud_src = 1
hdmitx: hw: Audio Type: PCM Audio Channels: 2, Speaker layout: 0x0
hdmitx: hw: Audio Output Channels set to: 0:0
hdmitx: fs = 3, cd = 4, tmds_clk = 148352
hdmitx: hw: aud_n_para = 5824
hdmitx: hw: set channel status, sample rate 3
hdmitx: [0x10000104]: 0x00000001
hdmitx: [0x10000180]: 0x000000ff
hdmitx: [0x10000181]: 0x000000ff
hdmitx: [0x10000182]: 0x00000003
hdmitx: [0x10000183]: 0x00000007
hdmitx: [0x10000184]: 0x0000003f
hdmitx: [0x10000185]: 0x00000002
hdmitx: [0x10000187]: 0x000000ff
hdmitx: [0x10000188]: 0x00000003
hdmitx: hw: [0x10e3] = 0x1f
***** AFTER.TXT
***** before.txt
hdmitx: video: DV type Not DV
hdmitx: video: PLL clock: 0xdb14049a, Vid clock div 0x000b0000
vout: new mode 1080p60hz set ok
***** AFTER.TXT
hdmitx: video: PLL clock: 0xdb1204f7, Vid clock div 0x000a739c
hdmitx: system: update rx hdr info 0
***** before.txt
fb: osd_update_disp_axis_hw:dispdata(0,0,1919,1079)
hdmitx: audio: Audio Type: PCM
hdmitx: video: VIC: 16 (16) 1920x1080p60hz
hdmitx: video: Video output
Bit depth: 10-bit, Colourspace: YUV444
Colour range RGB: limited, YCC: limited
hdmitx: video: Gamut
Colorimetry BT709
Transfer SDR
fb: osd[0] enable: 1 (init)
***** AFTER.TXT
***** before.txt
vlock: event MODE_CHANGE
***** AFTER.TXT
***** before.txt
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
***** AFTER.TXT
av out status: high av_mute_sleep_time:500
***** before.txt
fsck: Filesystem UUID: 7998c88a-97fa-451e-a5f8-d2c3257ea746
fsck: /dev/osmcroot: clean, 51041/1875968 files, 723774/7494656 blocks
cgroup: cgroup2: unknown option “nsdelegate”
***** AFTER.TXT
fsck: Superblock last mount time (Thu Jan 8 00:59:01 2026,
fsck: now = Wed Jan 1 00:00:09 2020) is in the future.
fsck: FIXED.
fsck: Free blocks count wrong (6770882, counted=6770874).
fsck: Free inodes count wrong (1824927, counted=1824917).
fsck: /dev/osmcroot: 51051/1875968 files (0.2% non-contiguous), 723782/7494656 blocks
fsck: Exit status: 1
systemd[1]: System time before build time, advancing clock.
***** before.txt
systemd[1]: Mounting FUSE Control File System…
video_framerate_adapter: loading out-of-tree module taints kernel.
***** AFTER.TXT
systemd[1]: Mounting Kernel Configuration File System…
***** before.txt
Registered frame rate driver success.
systemd[1]: Starting Rebuild Hardware Database…
register clk_set_setting cpu[50]
***** AFTER.TXT
systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
systemd[1]: Starting Load/Save Random Seed…
systemd[1]: Starting Create System Users…
***** before.txt
amvdec_h265 module init
***** AFTER.TXT
systemd[1]: Mounted FUSE Control File System.
systemd[1]: Started Journal Service.
usb 1-1: new full-speed USB device number 2 using xhci-hcd
***** before.txt
amvdec_vc1 module init
amvdec_vp9 module init
***** AFTER.TXT
systemd-journald[2391]: Received client request to flush runtime journal.
***** before.txt
systemd[1]: Starting Platform Persistent Storage Archival…
systemd-journald[2389]: Received client request to flush runtime journal.
***** AFTER.TXT
usb 1-1: device descriptor read/64, error -71
***** before.txt
***** AFTER.TXT
***** before.txt
aml_wifi wifi: [extern_wifi_set_enable] WIFI Enable! 481
***** AFTER.TXT
usb 1-1: new full-speed USB device number 3 using xhci-hcd
***** before.txt
***** AFTER.TXT
***** before.txt
proc: unrecognized mount option “hidepid=invisible” or missing value
amlvideo2.0 cma memory is 50000000 , size is 1800000
amlvideo2.0 cma memory release succeed
amlvideo2.1 cma memory is 51800000 , size is 1800000
amlvideo2.1 cma memory release succeed
EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
v4lvid: dbg: v4lvideo open
***** AFTER.TXT
usb usb1-port1: attempt power cycle
amlvideo2.1 cma memory is 50000000 , size is 1800000
amlvideo2.0 cma memory is 51800000 , size is 1800000
usb 1-1: new high-speed USB device number 4 using xhci-hcd
usb 1-1: New USB device found, idVendor=1a40, idProduct=0801
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB 2.0 Hub
***** before.txt
v4lvid: dbg: vidioc_close!!!
***** AFTER.TXT
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
***** before.txt
***** AFTER.TXT
EXT4-fs (mmcblk0p10): recovery complete
***** before.txt
[0]: vcodec_dec decoder ffffffc0dbf98000
[0]: release decoder ffffffc0dbf98000
***** AFTER.TXT
***** before.txt
RTL8211F Gigabit Ethernet: setting phy-mode to rgmii-rxid
***** AFTER.TXT
[0]: vcodec_dec decoder ffffffc0defd8000
[0]: release decoder ffffffc0defd8000
***** before.txt
RTW: module init start
***** AFTER.TXT
meson6-dwmac fdc00000.ethernet eth0: fail to init PTP.
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
usb 1-1.2: new full-speed USB device number 5 using xhci-hcd
***** before.txt
RTW: rtl88x2cs BT-Coex version = COEX20211210-2727
RTW: rtw_inetaddr_notifier_register
***** AFTER.TXT
***** before.txt
RTW: SetHwReg: bMacPwrCtrlOn=1
input: lircd as /devices/virtual/input/input7
RTW: is_valid_id_status: HALMAC_FEATURE_DUMP_LOGICAL_EFUSE
***** AFTER.TXT
***** before.txt
RTW: module init ret=0
osmc videoenhancement: session context configured successfully
***** AFTER.TXT
usb 1-1.2: config 1 has an invalid descriptor of length 0, skipping remainder of the config
usb 1-1.2: New USB device found, idVendor=2017, idProduct=1690
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: OSMC Remote Controller
usb 1-1.2: Manufacturer: OSMC Remote Controller
input: OSMC Remote Controller OSMC Remote Controller as /devices/platform/fde00000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1
.0/0003:2017:1690.0001/input/input7
input: lircd as /devices/virtual/input/input8
hid-generic 0003:2017:1690.0001: input,hidraw0: USB HID v1.10 Keyboard [OSMC Remote Controller OSMC Remote Controller] on usb-
xhci-hcd.0.auto-1.2/input0
.1/0003:2017:1690.0002/input/input9
***** before.txt
fb: osd_release now.index=0,open_count=1
***** AFTER.TXT
hid-generic 0003:2017:1690.0002: input,hidraw1: USB HID v1.10 Mouse [OSMC Remote Controller OSMC Remote Controller] on usb-xhc
i-hcd.0.auto-1.2/input1
Resync Failed. Files are too different.
***** before.txt
stmmac: Energy-Efficient Ethernet intentionally disabled
hdmitx: system: stream colourdepth was 8 in para 000000006419c66f (1920x1080p60hz)
hdmitx: system: display colourdepth was 10 in cur_param 0x0a871018 (VIC: 16)
hdmitx: hw: config hdmitx IP vic = 16 cd:5 cs: 1
Bit depth: 12-bit, Colourspace: YUV422
Colorimetry BT709
Transfer SDR
hdmitx: video: cur_param = param at 0x0a871018 colourdepth 10 colourspace 1
Colorimetry BT709
Transfer SDR
hdmitx: hpd: hdmitx: unlock hpd
fb: osd[0] canvas.addr=0xe9000000
fb: osd[0] canvas.width=16384
fb: osd[0] canvas.height=4410
fb: osd[0] frame.width=4096
fb: osd[0] frame.height=2205
fb: malloc_osd_memory, cma:ffffff800a9d3e70
fb: malloc_osd_memory, 1207, base:0x000000007f800000, size:8388608
fb: use ion buffer for fb memory, fb_index=2
fb: OSD2 as afbcd mode,afbc_type=2
***** AFTER.TXT
@sam_nazarko Hello Sam, I’m still waiting to hear back from you about the shipment for the Vero V remote adapter. The first shipment was lost in the mail back in November. I haven’t received any information on the status of the replacement shipment. I’ve sent several emails. Just wondering the best way to contact you.
Thanks.
Thanks, I’ll check this out.
Please try and keep things under just one email.
All the same symptoms: sudden death of remote, re-pairing and new battery don’t work
osmc@osmc:~$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0bda:9201 Realtek Semiconductor Corp. Ugreence
