https://paste.osmc.tv/elisofobak
Hello,
My Vero 4K is at update June 2020, but when I try to update it says no updates available.
I tried also with the command-line.
apt-get update
apt-get dist-upgrade
Also, TvHeadend is doing cyclic restarts, so I tried un-installing it with My OSMC, but now I can’t re-install it.
Any ideas?
Many thanks
Did you try the hotfix method?
Hi Sam,
I tried the hotfix.
It still shows ‘no updates available’
When I try command-line, it looks like it is already updated?
> osmc@osmc-Cavendish:~$ sudo apt-get update
> Hit:1 http://security.debian.org stretch/updates InRelease
> Ign:2 http://ftp.debian.org/debian stretch InRelease
> Hit:3 http://ftp.debian.org/debian stretch-updates InRelease
> Hit:5 http://ftp.debian.org/debian stretch Release
> Hit:4 http://ftp.fau.de/osmc/osmc/apt stretch-devel InRelease
> Reading package lists... Done
> osmc@osmc-Cavendish:~$ sudo apt-get dist-upgrade
I don’t know if this is the latest kernel…
osmc@osmc-Cavendish:~$ uname -a
Linux osmc-Cavendish 3.14.29-158-osmc #1 SMP Thu Apr 2 18:40:24 UTC 2020 aarch64 GNU/Linux
That’s still out of date.
Is it possible to reinstall the OS and take a backup? That’s the quickest route.
Best the other way around, take a backup and then reinstall a newer version of the OS and restore Backup afterwards
Yes, ok I will make a new install.
Is it possible to re-install on the command-line, ie without making SD card first?
thanks
No, you need SD Card or USB Stick with the new image
I did re-install with USB stick, and now everything perfect
Míle buíochas - Many thanks.
