Running 2016.06-2
How can I set it back to 1080p ? Using Confluence skin in Expert mode but could not find the screen resolution setting.
Thank you in advance
Running 2016.06-2
We have not changed hotplug or EDID parsing code for Vero 2 for a few months. Which version of OSMC were you on before?
I see that you are having problems with hotplugging in another thread: TV not "seeing" my Vero2 (sometimes) when turned on - #2 by sam_nazarko
We really need logs to know what’s going on. I would also suggest keeping with one thread so we don’t get too confused.
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
Enable debug logging, reboot your device, and upload logs via My OSMC → Logger.
Thank you very much.
Here is the log:
http://paste.osmc.io/enepurobad
Hope it does give you some clues.
Take care
I have limited connectivity, which doesn’t permit downloading logs very easily (sometimes the Internet here works and sometimes it cuts out) so maybe @DBMandrake can give it a quick lookover. Please also run these commands and post the output:
cat /sys/class/display/mode
cat /proc/cmdline (so we can see U-Boot setup)
cat /sys/class/amhdmitx/amhdmitx0/disp_cap
Does
echo 1080p >/sys/class/display/mode
Put your TV in 1080p?
Have you made any changes to your equipment recently?
Dear Sam,
I have found the proper entry in the Settings menu and had put back the GUI in 1080p manually so that problem is now apparently fixed.
I don’t know if the output you asked for is still of use but anyway here it is:
osmc@osmc:~$ cat /sys/class/display/mode
1080p
osmc@osmc:~$ cat /proc/cmdline
init=/init console=ttyS0,115200n8 no_console_suspend storage=1 vdaccfg=0xa001 logo=osd1,loaded,0x7900000,720p50hz,full hdmimode=720p50hz cvbsmode=576cvbs androidboot.firstboot=0 hdmitx= mac=08:61:60:11:27:1d console=tty0 consoleblank=0 osmcdev=vero2 root=/dev/vero-nand/root hdmitx=cecf quiet
osmc@osmc:~$ cat /sys/class/amhdmitx/amhdmitx0/disp_cap
480i
480i_rpt
480p
480p_rpt
576i
576i_rpt
576p
576p_rpt
720p
1080i
1080p
720p50hz
1080i50hz
1080p50hz
1080p24hz
No the Sony TV and Yamaha DSP are the same I had before with the Vero and then the Vero2 since I got it and I’m experiencing the “Vero2 not detected” glitch for a few weeks but not before. Sorry I am not able to be more precise.
Can live with it by ssh-ing and rebooting it via cmdline but it’s not optimal !
Thanks a LOT !
Robert
Looks like your TV doesn’t advertise a preferred mode of 1080p, so U-Boot picks it up as 720p.
Try powering your TV first, then your AV receiver to fix the ‘not detected’ issue. Otherwise we can possibly disable hotplugging.
Would also be useful when your TV is not detecting the Vero 2 signal.
Will try and report. Thanks a lot
