With some friends, we recently bought 3 Vero4k.
Sadly, the one I kept sometimes crashes:
Without any obvious cause, my TV screen goes completely black (no input). At the same time I lose any opened connections to the device (Transmission, FTP, SSH,…)
The issue happened while I was watching a movie, while I was browsing menus, and several times when I wasn’t even there.
When that happens, the only thing I can do is unplug the power supply, it does not reboot or come back even after hours.
I tried to reinstall OSMC twice.
I have nothing connected to the Vero4k (well, except remote, screen and network obviously)
I use a network drive mounted with fstab.
At first I thought of a software issue that would hopefully be fixed soon, but seeing that none of my friends got the same behavior at all, I’m not that sure anymore…
It depends. It’s possible there’s a display bug for the installer, as the display code isn’t as robust in that.
So depending on your display and the capabilities it advertises there could be a problem there. If the installer is successful your SD card should have a file called installer.log on it after running
I’ll check that as soon as I get home.
Though I don’t see why it wouldn’t be successful, at the end of the process I had to start my entire configuration from scratch, reinstall packages and so on.
I think you can consider this topic as invalid. I don’t know what changed but it does not crash anymore
I don’t think I changed anything, but as long as it stays that way, I’m perfectly fine with it ^^
Sadly, the issue came back. Debugging mode was enabled in the settings, but it looks like there is nothing more in the logs than last time.
Issue happened around 20:43 but there is nothing between 20:17 and 20:45 (time of the manual reboot)
The screen just froze with all CPUs to 100%. SSH, FTP and all web services stopped working at the same time.
Are you able to swap the PSU with anyone else (albeit temporarily) to see if it resolves the problem?
Do you have any background services running on the device?
I can’t think of why all cores would be at 100% in Kodi or playing back any media. If you’re running some other programs, does disabling them prevent the crashes?
Otherwise we can of course swap this out for you. If you have a program causing a crash though, I don’t want to send you a replacement and for you to have the exact same problem.
I’ll ask m’y friend to swap the PSU, just to be sure.
As background services, I have Couchpotato, Transmission, Sickrage, SSH and FTP server.
I also have Library Auto Updater and TVshow time, but I don’t think those are running in the background.
I recently added Headphones (the service) but I had the issue before.
I didn’t find anything about any of those causing problems, but I’ll try disabling everything and see if it keeps crashing.
I’ll keep you posted
Once it freezes I can’t take a screenshot so here is a photo ^^’
Have you tried with transmission disabled? If this is causing 4 CPUs > 99% and overheating, then that’s probably the issue.
I have Vero4K with Live TV (HD channels), and kids watching youtube videos, movies, etc. It’s running 24/7and doesn’t get hot, and CPU is always very low.
I also have ftp and ssh, but not transmission.
I don’t think CouchPotato/Sickrage cause high CPU, but definitely transmission does.
Also the Library Auto Updater - try disabling that.
