Hi, I’m getting a ugly smailing face when i’m trying play anything, stream, file, etc
This ocurs from 18.8-43 versions and forward
root@vero:~# aptitude versions vero3-mediacenter-osmc | cut -b -11
Package ver
p A 18.8-41  <= ok
i A 18.8-42  <= ok
p A 18.8-43  <= KO
p A 18.8-44  <= KO
p A 18.8-45  <= KO
I upload logs to https://paste.osmc.tv/xxxx, the old log is with 18.8-43 version and the log is with 18.8-42
              Looks like you are running nightly builds of OSMC.
You may wish to downgrade to a stable version if you want things to run smoothly.
              I guess you always need someone to try the latest and report.
I just want to report a problem, in case it’s helpful.
You should be reporting problems with the testing builds in the testing thread [Deprecated] Kodi 19 (Matrix) nightly builds for Vero 2 & 4K
thanks a lot and excuse my ignorance
