First post in here, been a happy user of the Vero for about a year without any complains. However, I updated to the recent release of Kodi today and now I am unable to play my movies, it plays well a few seconds and then jobs back to kodi/osmc. I am steaming from a NAS. FYI I haven’t touched a thing, worked without any problems before the update and if I am playing the same movies on the plex add-on in kodi, it works fine.
reproduce the issue
If your NAS supports SMBv3 then set that as both the min and max protocol and reboot. If your NAS does not support SMBv3 then leave that setting alone and enable the “Mitigate MTU issues…” option and reboot. If this is the issue a system mount will also work around the problem and give a network speed increase as well.
Great thanks to both of you, works with the quick fix you mentioned darwindesign. I haven’t updated the vero for some time, as it was working like a dream. Will fix system mounts later on to increase the speed somewhat. Again thanks.
I did but if I do so the “bar” at the left hand side, with the option to update library etc is not fully visible at my TV, which it is at 2160. May I ask why its better that way?
You need to turn off overscan on your TV. Depending on the TV it could have different names. Just Scan seems a common name for the option.
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
Unless you have connectivity issues which method you go with is probably irrelevant but instructions for each…
And to actually use them you will have to dump your library and add new sources or else take the path of least resistance and just put in a path substitution to redirect to the system mount.
