Power off: 18:27 GMT+1
The Box goes on without any remote input at 18:37 GMT+1
In this test I reduce the “Shutdown function timer” under System Settings>Power Saving to 10 Minutes and now the Vero4K powered on after 10 minutes. Before in my first test it was set to 30 minutes (see comment 1). So I think this setting has an relation to the problem.
But I don’t have set a timer or anything else. Okay what I do is, I shutdown the Vero4K during the TV playback. Here you had fixed a problem (No Standby during playback of TV or video)
Was this ever resolved. I have the issue the OP describes. How is best to diagnosed the cause?
I don’t have many addon’s except for keymap editor and trakt. I also don’t use PVR.
I disabled cec on the tv but it still comes out of sleep mode.
I don’t know if this is related but i have under system > power saving > sleep/shutdown that I have the vero set to suspend after 20 mins. If I disable this setting then the vero stays in sleep mode when I put it in sleep mode manually.
I only set this as I have an oled so didn’t want to leave a static image on the screen for too long.
I’ve disabled this setting now, will just remember to turn the tv off if I leave the room.
I just want to confirm that this is also happening for me.
The Vero 4K comes out of standby mode when the timer is set on but I have fixed it by turning off the timer. It now stays in standby when I manually do it.
