VeroV problem with some VC1 content
do you have an idea, why there is some VC1 content that plays just fine, but also some, that lags and where the audio drifts after a couple of minutes?
This one is mediainfo for a normal working one:
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Duration                                 : 1 h 43 min
Bit rate                                 : 26.8 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.538
Stream size                              : 19.3 GiB (88%)
Default                                  : Yes
Forced                                   : No
And the following one there the movie starts stuttering, only plays normal speed after I fast forwarded once. THen after a couple of minutes audio starts to drift. Can be fixed with fast forward/backward again, but starts drifting again:
Format                                   : VC-1
Duration                                 : 1 h 59 min
Bit rate                                 : 19.0 Mb/s
Width                                    : 123 pixels
Original width                           : 1 920 pixels
Height                                   : 123 pixels
Original height                          : 1 080 pixels
Display aspect ratio                     : 1.000
Original display aspect ratio            : 16:9
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 52.278
Stream size                              : 15.9 GiB (89%)
Default                                  : Yes
Forced                                   : No
Can you already spot an issue from the mediainfo and codec or do you need a debug log for both playbacks or video sample files?
Did you already give the Kodi v21 testbuild (see: [TESTING] Kodi v21 release builds) a try? There’re some VC1 related fixes in that testbuild.
But the drift issue was also reported to exist in that testbuild and I’m already investigating it.
nah I am waiting for final plus first bugfix release before I move on :slight_smile:
