Yesterday I encounter a problem with my Vero. I have Vero for some time and configuration is that it connects to my NAS, using mysql database. And yesterday after i clicked all movies Vero freezed completely (even logging stops) for few minutes and it looked like that:
All other network connectivity works fine - I can connect to my NAS, play a file using tablet, transfer rates are fine etc.
I saw that yesterday was some update applied and maybe this was the issue. I tried yesterday to reboot Vero and shutdown today, but everything freezed both times and I had to take off plug for both cases. I don’t turn off Vero at all, so I don’t know if it happened yesterday or was before that.
I had some changes in my network configuration - I’ve got a new router, but it worked for few days fine and yesterday stopped.
I could, but this would require a total fresh setup to be performed, as this router was reseted to clean.
I’ll do that this evening, but I don’t think it will solve the problem as new router worked for few days w/o any problems, before this problem occurred. And it happened after some updates I installed on Vero.
Is there in my logs anything pointing towards this slowness?
Ok, I’m officialy lost. I’ve switched to old router (which took me an hour, thanks IE and MS and it started to work perfectly fine. At the moment I have no idea, why my router is causing this kind of problems. I’ve created log file when I’m using old router, browsing my library, switching to new router and trying to browse. Link to logs
Maybe, if you take a look it would tell you anything. I’m going to TP-LINK forum for any solution, but with limited hope for solution
N600 Wireless Dual Band Gigabit ADSL2+ Modem Router
Model No. TD-W8980
As I’ve posted elsewhere, wireless performance with the Vero is poor compared with that of an RPi+ running OSMC. (The Pi is wired to an old Airport Express.)
I also have slow TV database browsing with the Vero. With the Pi, the list of TV shows appears almost instantly after clicking the TV icon. With the Vero, it takes five to ten seconds before the list of shows appears. It also takes much longer for a show to start up with the Vero than with the Pi.
I am running a shared MySQL database and shared media files, both hosted on a wired MacMini.
