Just testing a couple of jelly fish files, both of these appear to stutter over the network on the Vero 4K;
- jellyfish-180-mbps-4k-uhd-hevc-10bit
- jellyfish-200-mbps-4k-uhd-hevc-10bit
I’ve read about increasing a buffer size, but wasnt entirely sure where this is stored and where to edit.
As ive not modified any buffer settings, I can only assume mine are default?
Grabbed Logs: http://paste.osmc.tv/salosokile
180Mbps is quite higher than you will encounter with real world content. This is really a non issue.
The Blu Ray spec maxes out at about 100Mbps.
There’s no real world content with such a high bitrate so probably no point in adjusting settings
For peace of mind you may wish to try the demo clips from local storage
Yep, plays perfectly locally
Nothing to worry about then
If you have problems with feature titles, do let us know, and we’ll get this addressed.
