Hello
Just got my new Vero 4k+
As an experienced linux+kodi user i set it up immediately and noticed some issues so im asking if anyone has any idea of whats going on
Whenever i play a file no matter what the file on PlayerDebug i always get a VideoSync with negative values that fluctuates constantly. VideoSync should always be a positive value non fluctuating in order to get stable frames with stable frame pacing fed to your display.
Vero 4k+ is connected to a LG OLED CX. Same display was tested with HTPC and other brand box ( Don’t want to advertise it ) and VideoSync is stable.
Playback content is any - SDR or HDR , 1080p / 4k - all have the same issue
Auto framerate switching is enabled
Sync playback to display is disabled
What i tried to resolve the issue :
Updating to the testing 4.9 kernel
Updating to the testing Kodi 19
Forcing 10bit 444
Testing multiple HDMI 2.0 Ultra certified cables just in case
reproduce the issue
@Tom_Doyle , @sam_nazarko - debug log will be useless - video sync is not logged there. Do you really need the log ? I don’t have any dropped , repeated or skipped frames during playback if thats what you are asking.
For reproducing the issue i use any test file i can play. Anything you can think of.
The LG OLEDs from 2020 are very sensitive to frame pacing issues and it causes motion issues when doing 5:5 @sam_nazarko how does the VideoSync parameter work in AML if its not a trade secret ? Also have an older AML S905 box and VideoSync is always fine
If you have playback issues, we absolutely need to see debug logs.
But if you don’t have any playback issues, I’m not sure I understand what the issue is and what you’d like us to solve?
The source code is available on GitHub, but unless you’re familiar with PTS and DTS debugging I’m not sure if that will be helpful.
In late 3.14 and 4.9 kernels, we have devolved a lot of synchronisation to the kernel and not Kodi, so Kodi will not always report these correct numbers in userland. But unless you see issues, things are running smoothly.
To rephrase: is there a file which I can therefore play and will experience video playback issues?
@sam_nazarko ill send debug logs tomorrow
As i said i see playback issues with all files - any files
Kodi updates VideoSync on how fast the gpu accepts the buffered frame. Last time i’ve read that part of kodi’s source was ~2 years ago. Unless this changed - are you saying that the gpu path afterwards is not synced to Kodi because i don’t see how this is possible
The GPU is not used for video playback on any AMLogic platform, the VPU is used.
It’s a bypass render method, which is not the same on other platforms.
We have our own Git repository with downstream patches for AMLogic. AMLogic support has even been completely removed from Kodi upstream: https://github.com/xbmc/xbmc/pull/16043. We continue to maintain support downstream with our own decode approach.
You say
but also:
So what playback issues are you seeing?
Stuttering? Blackouts?
I don’t understand. Are you just talking about the number you see on screen when the playback debug dialogue is open?
If you are experiencing playback issues, please post logs.
The VPU outputs via the GPU correct? Its not directly connected to the HDMI port ? Are they using separate clocks ?
Im seeing weird frame pacing issues on a LG OLED CX. The LG OLEDs from 2020 are very sensitive to frame timing so if you send frames that are out of bounds for more than 8ms it has issues with 5:5 pull down. It expects frames to be sent exactly up to max 33ms for 23.976 or it starts having issues. All new OLEDs are like that from LG. VideoSync changing constantly shows how the frames are pushed to the VPU as you say then GPU then display probably arriving late causing issues ?
This is the current hardware i’ve tested with ( same file , multiple files , any SDR files obviously i coulnd’t test HDR on the Minix ( HDR lags ) and the Shield ( 8bit limit ) ) :
Minix U1 S905 AMLogic box - VideoSync stays positive and is not fluctuating - stable 23.976
NVIDIA Shield 2017 - VideoSync is messed up and always was on this device so it has issues since day 1 even on older OLEDs - can’t keep stable 23.976
HTPC with AMD gpu - VideoSync stays positive and is not fluctuating - stable 23.976
HTPC with NVIDIA gpu - VideoSync stays positive but is fluctuating however it works OK - semi stable 23.976
Vero 4k+ - VideoSync - goes from negative/postive - its all random , fluctuates constantly no matter if its negative or positive - 23.976 is never stable
I spent some time with a TV in my holiday flat but cannot reproduce the issue whatever video material I tried; videosync is always constant 0 or positive with low fluctuation.
Absolute, see @Tom_Doyle’s post above ! If you could provide a short demo clip out of your video material which let you reproduce the issue, it would be even more helpful to understand your issue. Let’s help us to help you and provide these data.
I know the recommendations
Any changes to the kodi settings don’t influence the videosync. Even the Kodi and kernel updates didn’t.
I’ve tested everything and that’s why im here
I’ll be of no help; with my current available TV in my holiday flat demo1 runs without negative videosync: Videosync is constant 0.0, not a single skip, drop or visual noticable negative effect.
But what I can see is that your audio config is sub-optimal:
From my point of view the most important questions is:
Do you see any negative effect while playing the video or only the videosync value is what concerns you?
Hey @JimKnopf :
Please read my posts before commenting.
For the second and last time - If your videosync is 0.0 it means its NOT working. 0.0 means that your display refresh rate is NOT set to the video refresh rate - you obviously have match refresh rate to display disabled or your vero can’t switch to the supported refresh rates on your display causing a 3:2 pulldown applied.
As i already said there are visible issues with frame pacing.
Also there is no such thing as sub-optimal audio config. Just because its optimal for you doesn’t mean its optimal for other people. As i said and im saying for the third time all options were tested before me reporting here ( VideoSync not perfect on Vero 4k+ [ SOLVED ] - #16 by alex11 ) .
Im really not impolite to you but i wrote you the same thing 2 times already and you still didn’t accept my response. Anyways thank you
PS If you need help getting that 23.976 playing fine on that 24hz you can set a custom adjustrefreshrate in advancedsettings.xml like that + enable adjust refresh rate + sync playback :
