Reopening the former issue from https://discourse.osmc.tv/t/high-load-low-cpu-usage-and-kernel-errors/71571.
After trying several ways to use the vsftpd built-in server I can’t resolve the following: When connecting to my pi via the ftp server and uploading/downloading files the load goes through the roof and causing a system crash after a while.
I tried the following:
- Disable via the OSMC menu and remove the vsftpd server via apt-get purge and reinstalling the server
- As above but then installing via apt-get install vsftpd
My pi has an excellent power supply, runs samba+pihole+transmission and KODI without any issues. Disabling those services has no influence.
System logs are here: https://paste.osmc.tv/xinuxaduse
piece of the problem lies here I think, I notice a kernel oops
6057.959559] Process vsftpd (pid: 15678, stack limit = 0xae3fa210)
[16057.965664] Stack: (0xae3fbc38 to 0xae3fc000)
[16057.970035] bc20: 000005a0 a8e53dbc
[16057.978239] bc40: 00000080 a8e53dbc 00000000 a4cc3800 ae3fbd04 ae3fbc60 8088c08c 80887a08
[16057.986439] bc60: 000005a0 00000e9a ae3fbcd4 81003024 00004002 00000040 38e38e39 ae3fa000
[16057.994636] bc80: 00010000 00000000 00000000 3ad3e379 00000000 00000000 adec4a88 ade1ee10
[16058.002834] bca0: ae3fbd04 ae3fbcb0 00000000 00000000 00028000 00000520 00000000 000005a0
[16058.011031] bcc0: 000005a0 00000080 7fffffff 481ae3cb 5ad36522 00000000 3ad3e379 ae3fbd40
[16058.019233] bce0: a8e53cc0 9faa2700 00028000 a8e53cc0 00000000 ae054780 ae3fbd2c ae3fbd08
[16058.027434] bd00: 807f2f6c 8088b5dc 00001000 000753a0 014000c0 af6ea2e0 00001000 00000000
[16058.035631] bd20: ae3fbd94 ae3fbd30 807f8518 807f2f18 00001000 ae3fbd40 a88f8000 00001000
[16058.043829] bd40: 00000000 00000000 00000003 00000080 00000f80 ae3fbd38 00000001 00000000
[16058.052026] bd60: 00000000 00000000 00028000 00000000 a8e53cc0 af6ea2e0 00001000 00000000
[16058.060230] bd80: 00000000 00001000 ae3fbdbc ae3fbd98 8088b568 807f848c 00028000 3ad3e379
[16058.068434] bda0: a8e53cc0 8088b4e0 9faa2700 af6ea2e0 ae3fbdec ae3fbdc0 808c1804 8088b4ec
[16058.076632] bdc0: 00028000 00002000 808c1790 ade66af0 00001000 00006000 807f38d4 000000f0
[16058.084829] bde0: ae3fbe0c ae3fbdf0 807f3924 808c179c 00028000 8035db14 abc0bb00 abc0bb00
[16058.093026] be00: ae3fbe74 ae3fbe10 8035db7c 807f38e0 ae3fbe40 00028000 ae3fa000 00000000
[16058.101222] be20: 00028000 00000000 00000000 00008000 ade66a00 0000a000 0000a000 00000000
[16058.109426] be40: 0000a000 00000000 00000000 abc0bb00 753afdac 8035d904 adec4a80 ae054780
[16058.117624] be60: 7ffff000 00000004 ae3fbedc ae3fbe78 8035ea30 8035d910 00000004 805a3364
[16058.125821] be80: ae3fbf14 00000000 ae3fbf00 8035d190 8035dd34 ae3fbf08 00010000 0ac4f254
[16058.134017] bea0: 0dd19000 00000000 0dd29000 00000000 00000000 adec4a80 adec4a80 9faa2720
[16058.142214] bec0: ae3fbf08 fffff000 00000fff ae054780 ae3fbf3c ae3fbee0 803123dc 8035e898
[16058.150417] bee0: 7ffff000 00000000 5ac8a5a9 2c6f9edc 4ddd738b 7ffff000 ae054780 00000000
[16058.158619] bf00: 030c9dac 00000000 00000000 00000000 8031cc80 00000000 00000000 00000000
[16058.166820] bf20: 000000bb 7fffffff 00000006 00000000 ae3fbfa4 ae3fbf40 80314d18 80312218
[16058.175017] bf40: fffff000 00000fff 030c9dac 7e9678a8 00000008 00000000 7e9678a8 805a380c
[16058.183214] bf60: ae3fbfa4 ae3fbf70 80311d18 805a37f0 00000000 00000000 030c9dac 42a0b8c5
[16058.191409] bf80: 7fffffff 00000006 000000bb 8010c7a8 ae3fa000 00000000 00000000 ae3fbfa8
[16058.199613] bfa0: 8010c5c0 80314bc4 42a0b8c5 7fffffff 00000006 00000004 00000000 7fffffff
[16058.207812] bfc0: 42a0b8c5 7fffffff 00000006 000000bb 00000004 0047ced0 0047ced0 00000004
[16058.216010] bfe0: 0047bc48 7e9678cc 004663d7 76c8e966 20030030 00000006 2f7fa861 2f7fac61
[16058.224227] [<80887a5c>] (tcp_push) from [<8088c08c>] (tcp_sendmsg_locked+0xabc/0x1038)
[16058.232261] [<8088c08c>] (tcp_sendmsg_locked) from [<807f2f6c>] (kernel_sendmsg_locked+0x60/0x78)
[16058.241175] [<807f2f6c>] (kernel_sendmsg_locked) from [<807f8518>] (sock_no_sendpage_locked+0x98/0xa0)
[16058.250520] [<807f8518>] (sock_no_sendpage_locked) from [<8088b568>] (tcp_sendpage+0x88/0xf0)
[16058.259073] [<8088b568>] (tcp_sendpage) from [<808c1804>] (inet_sendpage+0x74/0x158)
[16058.266840] [<808c1804>] (inet_sendpage) from [<807f3924>] (sock_sendpage+0x50/0x64)
[16058.274607] [<807f3924>] (sock_sendpage) from [<8035db7c>] (generic_splice_sendpage+0x278/0x430)
[16058.283418] [<8035db7c>] (generic_splice_sendpage) from [<8035ea30>] (do_splice_direct+0x1a4/0x370)
[16058.292500] [<8035ea30>] (do_splice_direct) from [<803123dc>] (do_sendfile+0x1d0/0x480)
[16058.300534] [<803123dc>] (do_sendfile) from [<80314d18>] (SyS_sendfile+0x160/0x4b8)
[16058.308223] [<80314d18>] (SyS_sendfile) from [<8010c5c0>] (ret_fast_syscall+0x0/0x28)
[16058.316079] Code: e5840514 e3110001 158404a4 e59b0004 (e595105c)
[16058.322548] —[ end trace 2f8723f1c26b4df9 ]—
[98138.949205] Unable to handle kernel NULL pointer dereference at virtual address 0000005c
[98138.957508] pgd = abd5c000
[98138.961985] [0000005c] *pgd=00000000
[98138.965645] Internal error: Oops: 5 [#5] PREEMPT SMP ARM
[98138.971005] Modules linked in: xfs 8021q garp stp llc iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_filter snd_soc_wm8804_i2c snd_soc_wm8804 sg snd_soc_hifiberry_digi snd_soc_bcm2835_i2s snd_soc_core bcm2835_thermal snd_compress snd_pcm_dmaengine snd_pcm snd_timer bcm2835_gpiomem snd i2c_bcm2835 uio_pdrv_genirq fixed uio ip_tables x_tables ipv6
[98139.006547] CPU: 3 PID: 27855 Comm: vsftpd Tainted: G D 4.14.26-2-osmc #1
[98139.014507] Hardware name: BCM2835
