I believe it’s possible if the remote you plan to use supports the NEC protocol.
It’s possible to implement this functionality in the bootloader, but we haven’t implemented suspend support in the kernel itself. There might be some unexpected behaviour as a result: Ethernet, CEC etc may not be in the right state.
I’m looking at supporting WoL support in the future and will take a look then. The CE BL301 injection method isn’t ideal and won’t work for signed / encrypted bootloaders.
If you give me your remote wake up code I can do a test build
Looking at this further - we can use SCPI calls from the kernel to make options like WoL and Wake with IR configurable by configuring the AO power domain tasks.
Then changes wouldn’t require a user to rebuild to make customisations. There are other issues to fix first to handle resume properly and there are some bugs with CEC resume where it has random wakeups. This needs to be fixed so we can provide a consistent wake up / suspend experience.
I’m not much familiar with the IR remotes, protocols etc., but the remote, I’m currently using, is the remote from some rather old LG TV. This is a snippet from the lircd.conf for it:
begin remote
name LG_AKB73715603
bits 16
flags SPACE_ENC
eps 30
aeps 100
header 9009 4498
one 541 1684
zero 541 553
ptrail 539
pre_data_bits 16
pre_data 0x20DF
gap 40180
toggle_bit_mask 0x0
begin codes
KEY_POWER 0x10EF
@sam_nazarko Would this be enough information for you? Is it even compatible with the requirements, you’ve posted?
after some searching and reading information on web I concluded, my IR controler is NEC compatible:
disabling kodi/lirc to get raw access to RC
osmc@stb-living-room:~$ sudo systemctl stop eventlircd lircd_helper@lirc0 mediacenter
osmc@stb-living-room:~$ sudo bash -c 'echo "+nec" >> /sys/class/rc/rc0/protocols'
osmc@stb-living-room:~$ ir-keytable
Found /sys/class/rc/rc0/ with:
Driver: meson-ir
Default keymap: rc-empty
Input device: /dev/input/event6
LIRC device: /dev/lirc0
Attached BPF protocols: Operation not supported
Supported kernel protocols: unknown other lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp cec
Enabled kernel protocols: lirc nec
bus: 25, vendor/product: 0000:0000, version: 0x0000
Repeat delay = 500 ms, repeat period = 125 ms
NEC code for the POWER key of the remote
osmc@stb-living-room:~$ sudo ir-keytable -t -p nec
Protocols changed to nec
Testing events. Please, press CTRL-C to abort.
1952.661600: event type EV_MSC(0x04): scancode = 0x408
1952.661600: event type EV_SYN(0x00).
^C
@sam_nazarko I suppose, this is the information, you requested. Can we now get a bit further?
I, for one, have never found the shutdown/suspend to be very reliable. I’ve had a Vero4k (not plus) for five years and in all that time I’ve never succeeded in getting the suspend to work reliably - or rather the wake up after suspend. More often than not the Vero is totally unresponsive when trying to wake it up after more than a few hours and I have to pull the plug anyway.
It may have something to do with having an AppleTV and the Vero4K both going into a HDFury Diva but AFAIR the suspend never worked reliably even before I got the Diva.
I don’t use my Vero as often as I used to so I now just use ‘shut down’ and pull the plug when ending a session. I’d really prefer a physical on/off button on the device itself …
Well I know this doesn’t help you but it is super stable and reliable here with the TV Off triggering the suspend mode and a click on the RF Remote waking it up.
I don’t doubt it. However I prefer to have CEC turned off on all my devices – I find it causes more problems than it solves. Also, I am often not turning off the TV when suspending the Vero. Usually I’m switching to another device, typically AppleTV.
It’s not a big issue for me as I’m not using the Vero that much. With energy prices what they are nowadays just turning everything off is the best solution anyway …
