I’m currently researching which Media Player best suits my needs.
I’ve tried Nvidia Shield but have some Problems with 25hz / 50hz Material.
So currently I’m back to my Raspberry Pi 3 with Krypton 17.6. It runs fine, BUT no HD Audio support and limited to 1080p.
What I need and just want to verify if Vero 4k is good for me:
-I only need Kodi, no Amazon App etc.
-4k Support
-HDR Support
-Audio Passthrough for HD Audio (DTS HD, Dolby HD, Atmos, Dts:x)
-Auto Framrateswitching 23,976/25/50hz
-Autoswitching 1080p/4k
-DVBViewer PVR Plugin with WOL via MAC-Address to DVBViewer Media Server
-Deinterlacing for 1080i 50hz German Television
-Flirc Support to use my Harmony 650
I’m thinking of getting Vero4k or Odroid C2 (I know its without HDR-support)
I thank you very much for taking the time to answer my thread
I have a FLIRC (from my RPI days). I used it for a while as I also wanted to use my Harmony but ended up using the IR receiver of the Vero. Works like a charm.
I just played around with osmc on my raspi 3 and found 1 thing missing compared to the raspi 3 with librelec…but probably you know how to “fix” it.
The DVBViewer Plugin in OSMC is a bit older than the one in Libreelec. For my it is missing the WOL Feature I stated in my first post. Can I get the newer DVBViewer Plugin also in OSMC?
Its the version 2.4.14.1 in Libreelec and version 2.4.11 in OSMC.
stretch-devel is the bleeding edge repository. This was just a message to Sam that we haven’t incorporated 2.4.14 yet.
I doubt you can use the LE binary. It would probably have to be one for the Odroid and even then no guarantees. If there are no wrinkles, it should be easy to get 2.4.14 into the next update.
As a workaround, can’t you just stop the server sleeping?
Hope its possible for you to implement it as its a major function for me. Electricity ist expensive in Germany and IT does make an difference If the Server takes 2W during sleep or 50W when turned fully on.
So a workaround for some time yes…but not for always
Thx alot for your effort. Cant wait to hold the vero4k in my hands …
I received the Vero4k today and set it up as a replacement for my raspi3 running kodi 17.6 on libreelec. It is connected to a Pioneer VSX-932 via HDMI and then via HDMI to a Sony 55W905 1080p TV.
Framerateswitching etc. is working as also the Audio via HDMI as DTS-HD, etc.
So 1080p mkv’s with 23,976 Frames run fine.
My Problem is Live-TV via DVBViewer which is very choppy and unwatchable. Most of the German Channels broadcast as 1080i and some as 720p in 50hz. Both resolutions are choppy. I cant find out why as resolution switching is working correctly and Pioneer as well as the Sony TV show 50hz when watching Live-TV.
If I connect the Raspi3 to the same HDMI Cable and Networkcable it runs absolutely smooth.
I also tried a USB-GIgabit-LAN-Card which did NOT help.
Playback is very choppy and sometimes the load/buffer icon appears.
Of course I updated to the october update. Version is up-to-date.
As it is setup exactly the same as the Raspi3 concerning Kodi/OSMC Settings, I believe the Problem is somewhere else.
How can you help me/ What do you need from me? Logs?
Also tried to attach the Vero4k without the Pioneer directly to a TV. Also tried different HDMI Cable and other TV. I have Sony 55W905 1080p and Sony55XE7005 4k. For both its choppy
Currently its a deal breaker for me as we wanted to use the vero4k about 80% for Live-TV.
NvidiaShield w. Kodi, Pi3 w. Libreelec and WIndows PCs as clients run fine with the DVBViewer Server.
I’ll try to install OSMC on my spare Pi3 tomorrow to see how it runs there. My other Pi3 with Libreelec does have the newer version of the dvbviewer Add-On.
Please feel free to contact me once you have the new version available so I can test and provide feedback to you.
