How is this supposed to work visually? Photos in the background cycling at set intervals?
This topic was automatically closed after 45 hours. New replies are no longer allowed.
Exactly, @eagerbeaver
@zetruz, the background slideshow option is now available in a test build on our staging repo…
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
Just coming back to this one… It would be possible, but only in v19. The current skin engine of v18 doesn’t have this capability. Unfortunately Team Kodi doesn’t seem to be back-porting this feature: https://github.com/xbmc/xbmc/pull/15767
I’ve asked whether back-porting this might be possible on the Kodi forum. Let’s see whether I’ll get any replies.
