I am already chatting to Sam about this directly so not raising a bug as such, but out of sheer curiousty can anyone tell my what the difference is between these 2 pictures?
Same timestamp both streamed from my NAS, one via the Vero and one via my Panny ub900.
The 2 things I notice as being different are the amount of detail in the dark (not just brightness levels I don’t think as the black is still black), and that the skin tones are much more natural (the darker one has a red / grey / blotchy thing going on).
The lighter one (Panny) is how i think the image should look, but curious to get other input.
So, strange problem now occuring. I can see the normal menu and naivgate around for maybe 8-10 seconds and then completely blank screen. No images or sound. Have unplugged and rebooted on seperate occasions, and get circa 10 seconds of normal behaviour, then nothing. Tried other 2 sources and they work fine, but Vero is fine. Any ideas??
Strangely the Fire TV is now exhibiting the same behaviour on an entirely different input which suggests it may be something else. However, I have had flawless playback for 2 years without anything like this, so the same behaviour on 2 inputs at the same time following a change suggests it is the same thing (no idea how updating the vero 4k would impact other player though…?)
You could just disconnect the Vero to make sure it isn’t causing a problem.
As to logs:
