Hey
Just updated to the April release of OSMC and noticed that ShaderToy visualisations no longer work. Further, it seems that the addon is missing. I’ve looked through the addon sections but can’t find it anymore?
Jamie
Hey
Jamie
You can still get it from this repository: GitHub - popcornmix/repository.popcornmix.storage.
I didn’t include this repository by default for now as I ran in to some issues with the visualisations.
Thanks Sam. Indeed, it doesn’t work.
Hi Sam
@popcornmix said that his implementation has been superseded by GitHub - xbmc/screensaver.shadertoy: Screensaver with shaders from Shadertoy for Kodi on all OS.
Could this be added to OSMC? At the moment I have successfully got the visualisations from an “untrusted” source (repository.virserg-1.0.0.zip)
Jamie
We can add it soon.
Any E.T.A yet? Waiting for this so that I can finally update my build. Thanks in advance
Not yet. There are a few issues with it that we are looking in to it
+1 for adding visualizations again. My beamer needs them
EDIT: just saw this post Kodi 19 (Matrix) nightly builds for Raspberry Pi - #247 by gmc
Does that mean I can remove the popcornmix-repo and activate a system add-on? Should I deinstall the popcornmix installations first?
Any updates, can’t wait to test so kinda curious about the progress…
I don’t have any updates yet
While the ShaderToy version from the virserg repo currently seems to be the best working version of ShaderToy for my RPi2 with Kodi Leia v18.8 it is also possible to use the offical version from xbmc repo with some additional modifications:
The first issue is caused by the cmake scripts to first look for GL and only after that looking for GLES presence. The addon doesn’t work with GL but needs GLES. I’m not sure if this is specific to RPi2 and if it would be possible to have GLES w/o GL on the system to avoid the detection issue.
The second issues was some change introduced mid last year in the xbmc repo. The difference between GL_RED and GL_LUMINANCE is only how the audio data gets transfered into a texture used by the ShaderToy shaders later. With GL_RED the data is placed only in the red color component while GL_LUMINANCE places it in all color elements. This shouldn’t be an issue as long as the shader will only access the red component later but somehow there is no audio data at all with GL_RED specified. So changing it back to GL_LUMINANCE will bring the audio data back.
I used the following procedure to build the ShaderToy addon from xbmc:
sudo apt-get install git, cmake, zip, gles2-mesa-dev
git clone --branch Leia https://github.com/xbmc/xbmc.git
git clone --branch Leia https://github.com/xbmc/visualization.shadertoy.git
cd visualization.shadertoy && git checkout 1.2.4-Leia && mkdir build && cd build
cmake -DADDONS_TO_BUILD=visualization.shadertoy -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=../../xbmc/kodi-build/addons -DPACKAGE_ZIP=1 -DAPP_RENDER_SYSTEM=gles ../../xbmc/cmake/addons
make
cd ../../xbmc/kodi-build/addons && strip visualization.shadertoy/visualization.shadertoy.so.1.2.4
zip -r --symlinks visualization.shadertoy-1.2.4.zip visualization.shadertoy/
You can then install the addon from the resulting ZIP in ~/xbmc/kodi-build/addons
There are some of the shaders that don’t work (black screen) and I think there was one that crashed the addon (you will manually need to modify the settings file to change the current shader).
