Any help here please
also why won’t it bitstream the correct audio, its not showing Atmos just pcm
any help would really be appreciated tia
What version are you on?
Did you configure audio settings under Settings → System?
hi Sam
i’m on Oct 2020 and yes we have configured the audio
it’s done this before regards the audio and doing an update seemed to cure it, for whatever reason unknown to me now it doesn’t want to update
Without logs, or a demonstration of the problem, nobody will have the faintest idea, either.
So help me to help you with what you require
A photo showing that it won’t update and/or showing pcm won’t help you so explain what you ask so i’ll do my best to supply what you need if you tell me
Allan
reproduce the issue
Regarding configuring audio, see Audio hardware and software configuration - General - OSMC.
hi everyone
so a bit of an update, I’ve taken some screenshots which I hope will allow you to see what’s happening, I’ve disabled sync playback to display and rebooted twice as recommended and that seems to have cure the audio playback, all my other settings were correct afaik.
I’m still unable to update though, it’s still saying no available updates and as I type this, the Updater - Cache Updated-please wait window is still showing on screen
any further help and ideas would be most welcomed
Allan
There is currently no update newer than your November 2020 version unless you change to the Testing Version of OSMC. The next stable update is expected in the next weeks.
Your device is already on the latest version.
Haha!!
so that clears that little issue up then lol, so it appears I’m good to go and working fine
Many thanks, especially on the audio side because that had me stumped tbh
Thanks everyone, Allan
My Vereo 4k does not want to update manually either.
Version installed: OSMC November 2020 2020.11-1
According to the OSMC homepage, the latest version should be 2021.12-1, right?
Have you tried the hotfix?
Which HotFix ID do I have to enter?
It’s explained in this link.
Hotfix ucawobahij worked.
Thank you for your notice
