On a previous version of OSMC i was able to enable hot spot tethering that allowed my phone/tablet to connect to my osmc box so o could stream movies to my tablet/phone remotley, however the latest version for what ever reason is not doing this any ideas
I take it your using a RPi. If so then read this…
Thank you so i take it is is currently not supported because of the kernal update. will this be fixed or would i need to purchase a usb wfi dongle instead of relying on the internal wifi adapter
Is this effecting all versions including openelec or libra elec
If the realteck drivers are no longer being supported which one of these will work.
https://www.amazon.co.uk/s?k=Wifi+Dongles&ref=nb_sb_noss_2
GL.iNet GL-MT300N-V2 Mini Travel Router, WiFi Converter, OpenWrt Pre-installed, Repeater Bridge, 300Mbps High Performance, OpenVPN Client
We don’t support these distros so we can’t advise on what they may or may not support.
It will work again in a future kernel update but there is no ETA for that presently.
