Is there a fix coming for the zoom function not being centered?
Unless you have a reference to a github reported issue or any post on this forum it would be hard to answer the question as no one could know about the issue and therefore could not tell if a fix is coming.
If there is no existing report for your issue then please describe the issue and provide respective debug logs.
I noticed this same issue. The video zoom setting does not zoom from the center, it zooms from the top edge of the screen.
Was not an issue on my previous veros.
Would have been much easier if you would have asked in that thread.
Anyway based on the two responeses in that thread
Don’t expect a fix anytime soon.
