Firstly thanks for looking at my post. I must mention I have basically no knowledge of using the command line other than using iperf3 earlier to test my speed so please forgive my lack of OSMC knowledge.
I have a Vero 4K and a Vero 4K+ (as of today) and on both devices, when streaming 4K movies from my PC via NFS (Hanewin) & Powerline (Netgear AV1200) they continuously buffer and stutter and become unwatchable. I have been using Hanewin for many years on several devices and am confident it is performing as it should.
I did manage to test my speed using iPerf 3 and the results ranged between 91 - 104.
I have tested the 4K files using attached storage they all play perfectly.
1080P content streams perfectly using the network.
To eliminate the powerline as the culprit I have an eGreat a5 here so I reconnected it using the same ethernet cable as my 4K+, attached to the same NFS share and all my 4K movies stream perfectly so I’m a bit baffled baffled.
Could this be a buffering issue? Going back to last Autumn I could watch 4K movies on my Vero using the same setup without fault. Has the buffer size changed? Is that a possibility?
Do I understand that you only experience the problem on your 4K, and not 4K +?
How is the NFS share mounted?
For 4K, you may need to use an fstab mount due to the lower network throughput.
Are you playing the same files as before? 4K UHD rips have become more demanding as of late.
Hi Sam and thanks for the reply. I have exactly the same problem on the 4K and the 4K plus. I bought the 4K plus hoping it would solve the issue ;).
I am using Hanewin on my PC as the NFS Server. I have done for many years now. The software is always updated to the latest version. My media files are all on an internal hard drive on my pc. I have 3 separate shares on Hanewin.
The one in question is;
e:\media\movies\4K -public -name:4K
I did attempt to create an fstab mount but even with the very helpful walkthroughs I could not get it to work. Maybe Hanewin makes it more complicated or my folder structure causes an issue. Some of the files, Wonder Woman for instance, my wife and I watched it in glorious 4KHDR on my Vero back in October along with many other movies. ago and it played perfectly. Today the same file stutters and buffers. It just frustrates me as they play on the eGreat but I want rid of that box as the support is bloody awful (and I like the whole feel of OSMC).
Ok, so the limit here doesn’t seem to be the Vero4(k) Ethernet or Gigabit Ethernet interface but the throughput of the Powerline adapter.
Considering that values your current option is only fstab based mounts as the throughput you reach is really borderline for 4k (check the mediainfo of the 4k file to understand the required bandwidth).
I only can recommend to try it again. Either via fstab or autofs. Suggest you start with giving the hanewin version details and showmount output from the Vero.
As Powerline performance changes depending on external influences this could be easily the issue.
Actually I have a TP-LINK AV2000 and after 2 months I went back to my trusted 100Mbit cable as the throughput of the powerline was fluctuating too much. Even so there were days where it was well above 100Mbit there were also times where it was far below.
Thanks for the late night responses chaps, I’m really grateful.
Ok, as far as new equipment there is nothing new in the mix.
Hanewin I am using version 1.2.36 (latest release)
I will post the show mount info as soon as my very awake and wild 2 year old lets me escape ;).
My only question is why would the egreat play them without hitch? Could it possibly have a bigger buffer so it isn’t effect by a sudden drop in connection speed?
I don’t know how which libraries the egreat is using for mounting the NFS folders. As indicated possible FSTAB based mounts would remove your issues.
I am not sure if the -public switch is equal to allow all ranges as I before only have seen Hanewin users haveing the -range option. Maybe someone wiith a Hanewin can confirm.
Well I personally would try it via autofs (even so fstab should be similar).
Read this thread (second part)
Basically your /etc/auto.nfs.shares should look like this
/mnt/UltraHD 192.168.0.2:/UltraHD
When you have followed all the steps in the HowTo let us know if success or not, we then can troublehsoot.
I have tried that chap but I still get the error message. I’m wondering whether or not I should try the whole path of the share used by Hanewin??So instead of just mnt/UltraHD should I try “mnt/media/movies/ultrahd”??
This is how it appears. Its odd it shows the -public which is a flag used in Hanewin to give open access to the shared dir instead of it being passworded
osmc@osmc-Aloysius:~$ showmount -e 192.168.0.2
Export list for 192.168.0.2:
/UltraHD -public
Thanks for all your help guys but I’m starting to feel this is a little above my pay grade. Maybe its using Hanewin that is causing a problem but it is all I know.
For now I have the eGreat for my 4K collection its just a pain as I wanted it all on one box.
