There have been questions on various forums concerning getting 5GHz WiFi to work on the RPi. I thought I’d share my experiences.
My RPi2 was using an Edimax nano 2.4GHz adapter that was quite slow and there was interference from the ~40 neighboring networks, the 2MB/s (on a 72Mbps link) was plenty enough to stream movies but using my microwave oven would cause stuttering or even disrupt streaming completely. Sometimes the adapter would just lose link and need reset.
I bought a Tenda W522U dual band adapter to use with my 5GHz network.
I plugged it in via a powered USB hub. OSMC found the adapter but site survey only showed 2.4GHz networks, not my 5GHz SSID. ![]()
So I installed the “iw” utility (“sudo apt-get install iw”) and set the regulatory domain to Canada “sudo iw reg set CA”. However, still no luck.
With iw I listed the supported frequencies for my regulatory domain:
osmc@osmc:~$ iw reg get
country 00: DFS-UNSET
(2402 - 2472 @ 40), (6, 20), (N/A)
(2457 - 2482 @ 40), (6, 20), (N/A), PASSIVE-SCAN
(2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 160), (6, 20), (N/A), PASSIVE-SCAN
(5250 - 5330 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
(5490 - 5730 @ 160), (6, 20), (0 ms), DFS, PASSIVE-SCAN
Looking at the router setup, it used channel 149, which according to Wikipedia is 5745MHz. Clearly not supported according to the list above, produced by iw.
I changed my router to use channel 44 (5220MHz) and OSMC now shows and connects to my 5GHz network. I typically get 10MB/s download from the NAS, which is probably ten times more than I need for streaming and the link is stable.
Link characteristics/speed can be monitored with the wavemon utility (“sudo apt-get wavemon”).
TL;DR: If you want to use 5GHz make sure to use the right regulatory domain (with iw) and that your network is on a supported channel/frequency.
