Will do
Ok, again the signal 28 message ![]()
ok, now one more try. Stop the manual started autofs with CTRL-C
Then
sudo automount -f -d
That will give you many lines. Where maybe a screen shot doesn’t work anymore and you would need to copy and paste but let’s see
Different than before or using the command line?
Same on the command line. Just where you started that command stop it respectively
Stop it using this, right?
Nope stop with
sudo systemctl stop autofs
But as you have manually started it in one session either close that session or do CTRL-C
Wow, it’s been running for a while. Does this create a pastebin URL?
No, just stop it with CTRL-C
This one doesn’t create pastebin you would need to copy/paste
expire_cleanup: sigchld: exp 4104123472 finished, switching from 2 to 1
st_ready: st_ready(): state = 2 path /-
st_expire: state 1 path /-
expire_proc: exp_proc = 4104123472 path /-
expire_cleanup: got thid 4104123472 path /- stat 0
statemachine:1500: got unexpected signal 28!
Ah ok, I assume the initial part was cut off by too much repetition.
I think we need to have a fresh start to see whats going on.
Let’s do some step back:
- disable autofs with
sudo systemctl disable autofs - Reboot
smbclient \\\\192.168.1.180\\Multimedia -U <user> <Password>
You should be presented withsmb: \>there typedirand you should see files
For some reason it’s not allowing me access
Maybe try with your Home\ Media share instead
Also don’t include the < > keys?
Just… username password?
Correct
No mate. No joy…
I guess it’s not in the stars…
What happens? Any error?
I’ve tried with and without passwords
No difference
