Atmos
Hello,
If i’m not wrong using osmc with raspberry pi 3 dolby atmos won’t work right? I had another media player (wdtv) and everything wored it auto detect dolby atmos. If there is a limitation only with raspberry then is it going to work if I buy Vero 4k ? Thanks
Seems the answer is yes
It won’t work as the HDMI port of the Raspberry Pi 3 is limited to 24bit 48kHz 8 channels which doesn’t allow for HD audio bitstreaming (which requires a bandwidth of 24bit 192kHz 8 channels to work). Without HD audio bitstreaming there’s also no Atmos: it’s just metadata added to an HD audio stream - either Dolby TrueHD or Dolby Digital+. :wink:
The only device that supports this without problems is the Vero 4k. :+1:t2:
And I’m too late :joy:
