I’ve set up a server where my video files are stored. I can watch the movies from there over a Samba share with no issue on my Mac computer. However in Kodi (OSMC - Rpi3 - last update from MyOSMC), none of the files I’ve tried are watchable. It stops, image freezes or caches, or the sound is stuttering or even muted. It happens with many different movies (every one I’ve tried with) but still here is a media info of one of said movies: http://paste.osmc.io/xecutotiqu.vhdl
I would have if I could. I have no screen at my disposition that could be moved close to the router and have no idea as to how I could test video playback without a screen.
I use the integrated WiFi chipset of the Rpi 3. Internet streaming is very smooth with fast caching.
I’ve tried with a WiFi dongle I have here, it was worst. Mind you it is an old one.
Is there maybe some tuning up I could do to kodi (I don’t know buffer or something like that? ) or to the samba share to get better performance. If my mac computer can read the files flawlessly, this should be possible on the pi too, or I m totally wrong?
I’m not sure what you mean? You have shown your example as below, my example will follow:
//share/dir /mnt/myshare cifs username=user,password=pass //192.168.1.65/ /mnt/Video cifs noauto,x-systemd.automount,username=osmc,password=osmc 0 0
I’m not suggesting to use the line I’ve provided as an example. My previous suggestion is actually to also use the noauto,x-systemd.automount options in your fstab line. Remember, format and spacing is important here. No spaces, only commas between the options.
Ok it was just a misunderstanding. I thought that in your example username and password were related to the default osmc user in your example while we were both talking about the user for the share. I am a real beginner sorry.
Well, your options do work ! Thanks! So basically what does it do? It does not mount at reboot but when? Anyways seems fully functional now ! Thanks a lot.
Hi, I think i encounter the same problem with my smb-wifi sharing. For small files (<1Go) it works, but It’s awful with a 2-3 or 4 Go file : impossible to watch the movie properly !
It’s not a problem of my wifi because when I stream films over the internet, it works fluently (even for 1080p sources) !
So please, @th0m or @DBMandrake could you detail what you did to solve the problem ? Where do I put the lines above ?
Thanks !
Thanks for your link that I have followed yesterday. I have no error at any moment but when I test cd /mnt/Videos (the name I have chosen for the share), I can read « no such device » therefore I cannot access to the share.
My « server » is a hard drive connect to my internet box. I think I make no mistake with the 192.168.1.1 IP but I’m not sure about the password since I normally access to it as Guest (no login/pwd) on my Mac for example.
In the example, how is the shared folder « videos » defined in OSMC ?
Is there a way to show you exactly the issue or my local settings ? Thanks again. Pierre
You can try to remove password and use username guest but generally that is not supported by this method. So suggest that you check your internet box.
Alternatively why not move the harddisk from the internet box to the Pi and share from there?
You mean that you think that it is just a password matter as I describe the issue ? I have to try the options "username=guest, password=, " if I understand you well ?
I think I can’t easily move the hard disk since my Pi is on the ceiling connected to my video projector. And plus I use the same hard drive to broadcast music to my internet gateway… BUT maybe that you’re trine to tell me is that it’s possible to use the Pi to to this ? Upnp share ? And how to access to the HD from my Mac of iPhone in that case ?
Well not sure on your orginal issue but for now you can try to change those values but would suggest to check on the internet box to create that users.
Yes you can install the Samba Server from the OSMC app store that would allow you to share the drive from the Pi similar to your internet box. That would then also be reachable by Mac and Iphone.
DLNA/UPNP is another option but samba is recommended
