I’ve recently acquried an OSMC 5Ghz dongle and am facing similar issues on my Rpi 2.
I’ve checked that the Dongle works on my laptop.
On the Rpi2, I’ve unplugged all usb devices (aside from the dongle) to make sure it wasn’t a usb power issue.
I moved the /lib/firmware/mtu7610.dat file and rebooted.
Then I ran the connmanctl commands and still no wifi is found:
osmc@osmc:~$ sudo connmanctl
connmanctl> agent on
Agent registered
connmanctl> scan wifi
Error /net/connman/technology/wifi: No carrier
I am also attaching the log file in case someone can help me:
Not sure what the issue is but, connmanctl doesn’t show the 5ghz network on the list of “services”, however if i run iwlist, the 5ghz network shows there… so it must be something to do with connmanctl right?
Same problem here. Neither with gui nor with connmanctl I can see 5GHZ networks. Indeed I can see my 5GHZ network (to which I’m trying to connect for several months) when using iwlist.
Ok, than I am out of ideas. I can see all my AC networks in connmanctl when starting clear. But when I am connected to my 2.4GHz I also loose visibility of the AC networks. That was why I asked.
OK I’ve tried it again. I deleted the saved network AND I changed the channel from 116 to 36. Afterwards I was able to connect to my 5GHZ network.
Unfortunately the connection is incedibly laggy. It’s hardly possible to use SSH. Sometimes after a reboot there is no connection at all. Though the router tells me a speed of about 300 Mbit/s (similar to wavemon). I tried iperf betwenn the wireless Pi and a wired Pi. The result is a speed of about 40-50 Mbit/s.
Don’t know what else to try. Cable would be the best solution but that is not possible at all.
At 5GHZ the signal level is about -60dBm. The lower channels have a better signal level.
I disabled background scanning. 2.4GHZ is now way better. Thank you for that. Actually I thought that this had been solved.
I haven’t tried it with 5GHZ because it’s hard to connect any peripherals or ethernet cable with my setup. I will check it later this week.
Yes it was better with 2.4GHZ. The signal level was about -70 to -79 when using channel 56 and above. When testing the pi was located near the router. Now it is more far away and fixed to a wall. The 2.4GHZ connection is now also at about -60 dBm.
Ok, not sure if we have a misunderstanding here but lower numbers means better signal! So with -70 to -79 you would for sure run into background scanning issue as that would only bet stopped below -65 (AFAIK)
