I made a log hoping I could figure out what’s wrong but I’m a bit lost because there are hundreds of errors. I’m leaving it here hoping someone could come up with some suggestion: https://paste.osmc.tv/ulutihakib
Some additional infos:
I’m using the CV out, I have no hdmi display to test.
Boot will display OSMC logo, forever.
Issuing a “systemctl status mediacenter” command would return “Active: active (running)”
Is there something else I can do to troubleshoot the situation? I’m running a dist-upgrade every day, hoping something get fixed but I’m losing hope. What can I do to figure out exactly what’s broken? Any hint?
So the idea is to connect once a HDMI display, have tvservice -d write its data to file (no matter what data) then use these as dummy values to somehow fool the RPi?
I spent an hour last night trying all combinations of recommended fixes (cmdline and config) to get composite video to work. At one stage I had the OSMC splash screen but kodi stopped at that. After that I failed and couldn’t even reproduce that. So frustrating that the terminal hangs on the PC attempting to connect via ssh.
The answer must surely be in RPi forums somewhere.
OSMC runs it’s own Kernels. So you would need to wait till that fix is implemented in the OSMC Kernel and then published (most likely first in the development repository)
