Component video can be configured by editing /etc/X11/xorg.conf.
For 720p output:
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "RegistryDwords" "RMDisableRenderToSysmem=1"
Option "DynamicTwinView" "false"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
Option "UseDisplayDevice" "TV"
Option "TVOutFormat" "COMPONENT"
Option "TVStandard" "HD720p"
Option "TVOverScan" "0.80"
DefaultDepth 24
Option "NoLogo" "True"
SubSection "Display"
Modes "1920x1080" "1280x720" "1024x768" "720x480" "800x600" "640x480"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Disable"
EndSection
For 1080p output:
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
Option "TVStandard" "HD1080p"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
EndSection
Older TVs such as Samsung may not support 1080p, so the following line needs to be changed for 1080i:
Option "TVStandard" "HD1080i"
After editing, restart your system by issuing sudo reboot
Spinner
Split this topic
5 December 2015 22:49
2
4 posts were merged into an existing topic: Configuring composite output
u 4got to change 720p to 1080p
Look again. it was changed on Dec 2nd
Sorry for the daft question,
i am trying to configure this, i copied the file to my PC with WinSCP, edited and tried to copy back but get access denied. also the same if i try to edit the file directly on the ATV with WinSCP.
is there something else i need to do to get permission to replace or edit the file?
i am logged in using osmc/osmc, do i need to log in as root?
what would the password be?
Thanks!!
Root password is not set by default.
Suggest you copy the file to /home/osmc then ssh into the atv and copy with sudo cp /etc/X11/.
Where did I go wrong?
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 340.46 (buildd@binet) Tue Oct 7 08:03:22 UTC 2014
Section "ServerLayout"
Identifier "serverlayout0"
Screen 0 "screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "InputDevice"
# generated from default
Identifier "Keyboard0"
Driver "keyboard"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "monitor0"
VendorName "SNY"
ModelName "Sony TV"
Option "DPMS"
EndSection
Section "Device"
Identifier "device0"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "screen0"
Device "device0"
Monitor "monitor0"
DefaultDepth 24
Option "NoLogo" "true"
Option "ModeValidation" "NoVertRefreshCheck, NoVesaModes, NoXServerModes"
Depth 24
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Start a forum post if you’re having problems, explaining what these problems are.
I started a new thread, but I haven’t gotten any responses in the past 11 days since I started the thread: Apple TV Component Config - Where’d I go wrong?
Thanks first for your posting and I got my component video working. However, the analog audio output got low sound and bad quality. I installed this new OSMC KODI with a Usb and I know my atv1 hardware is good. I still kept my old Apple OS with XBMC Eden version and audio worked great. Can anyone help me on how to fix this?
Stavr0
22 October 2016 15:53
14
Older TVs such as Samsung may not support 1080p, so the following line needs to be changed for 1080i :
Thank you for this suggestion. Amended the post.
Stavr0
12 November 2016 19:37
16
