Since updating to kodi to v19 on my new vero 4k+ (I also reinstalled to make sure).
When the systems turns on it runs fine, till I usually turn the TV off go to bed, come morning, when you turn the tv on the TV says “no signal” and kodi won’t respond via GUI, I can ssh in just fine.
There is a Red X on the kodi box.
If I pull the power it restart and runs fine. Till I let it sit idle for a period of time again.
Obviously, but after spending 8 hours dealing with servers all day, logging into my tv box to reboot, sometimes takes a back seat to “I just want to watch tv” so the power gets pulled. But thanks for your concern, yes a sudo reboot would be the proper way.
I have the same problem, but it is intermittent (and without the red X). It may happen in 1 day or 10 days.
The above mentioned setting (Settings → System → Input → Peripherals → CEC Adapter → When TV is switched off → ) is set to “Ignore”.
I will try to provide logs when it occurs again. Anything else that I could try in the meanwhile?
