Thank you. I’m not sure if that’s the same issue. But it seems like a pretty major problem if you can’t resume what you were watching without a bunch of manual intervention.
Reading that thread, it seems only some videos are affected. Are you seeing this with every video? If so then you should start a new thread as this one should be about the title is.
Hah. Yeah. It’s movie-dependent (see my reply above yours). Interesting. So perhaps it is the same issue as the one you linked.
Movies behave weirdly. I am at 1:27:46 in Terminator Salvation, after successfully skipping though and stopping and resuming multiple times at multiple time stamps. Now, however, I skipped to 1:45:00 and when I stopped and resumed it resumed at 1:27:46 again despite saying it would resume at 1:45:00.
That’s a Kodi issue then… I can’t control how and when the infolabel used is populated. When playback is starting (while the busy dialog is active) the infolabel is not yet populated and therefore the playback time and the current time are the same as well as current playback position and playback length are all zero.
For me, most media is available right away and therefore I don’t really see the still empty now playing information and the busy dialog. The longer that period of starting playback lasts, the information you’re describing is show, of course.
Ok so on my second Vero 4K+ with the October, 2019 update it resumes fine. Everything looks great. I can tell it will resume fine because it actually shows up correctly on the top right of the screen for those few seconds showing the resume time. See attached.
I’m now updating the second Vero to the January, 2020 official build and will provide more info.
