While the option “Show empty TV shows” is disabled, my Vero 4K+ device is still showing the empty TV shows. I am using the skin ‘Eminence MOD v2.5.4’, but the problem also occurs when I use the standard OSMC skin.
I’m also using the cleaning option of Library Auto Update after updating the library.
I went from ‘Main Menu’ to ‘TV Shows’ and then to an empty tv show. After that I pressed the back button until I was at the main menu again. Nothing more.
There is a little difference with the other thread, a back navigation doesn’t fixes the listing at my device.
Eminence, but it’s also not working the with OSMC skin. I didn’t know it was skin related? (thought it was OSMC related since it doesn’t work with multiple skins…)
If you say it’s skin related I could test some things for you to help (please let me know), but personally I would search for another skin since OSMC skin is not my taste.
Thanks for clarifying. It does seem to be skin-related as far as I can tell, though I’m no expert in the dark art of coding skins.
On this forum, testing the OSMC skin would be most productive, though I understand that it wouldn’t be so productive from your perspective. If you want to stick with Eminence, you’d do best getting in touch with its developer(s) and explain the problem. Otherwise, as you say, you should try a few different skins.
jfyi: I can reproduce the issue if the empty TV show folder DOES NOT have owner osmc and group osmc but root:root.
So, I suggest you try to change the owner and group of all your TV show folders recursively to osmc:osmc. Don’t forget to update the library, afterwards.
Update+Warning: After I set the ownership to osmc:osmc I was not able to reproduce the issue anymore. So, not sure what the root cause really is.
