Hi Sam !
I hope you have a nice weekend !
So I have looked for streams in wich the audio was broken at 1080p@60fps in the vero 4k using the twitch addon then i went to my pc and captured those streams using http://docs.livestreamer.io/ so i got the original stream capture. I then tried playing those files on the vero 4k to see if its an addon problem and i found out that the videos will have broken audio even if i play them from the HDD.
I made samples of this videos for you here.
Sample 1
General
Complete name : R:\samples\jowe.mkv
Format : MPEG-TS
File size : 123 MiB
Duration : 6 min 15 s
Overall bit rate : 2 747 kb/s
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 6 min 16 s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 48.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Menu ID : 1 (0x1)
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Bit rate mode : Variable
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Menu
Menu ID : 1 (0x1)
List : 256 (0x100) (AAC) / 257 (0x101) (AVC) / 258 (0x102) ()
http://www.mediafire.com/file/75z4u8rd9e79kpb/sample1.mkv
Sample 2
General
Complete name : R:\samples\pit.mkv
Format : MPEG-TS
File size : 176 MiB
Duration : 5 min 43 s
Overall bit rate : 4 284 kb/s
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=120
Codec ID : 27
Duration : 5 min 44 s
Bit rate mode : Constant
Nominal bit rate : 4 000 kb/s
Height : 720 pixels
Frame rate : 60.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.072
Color range : Limited
Matrix coefficients : BT.601
Audio
Menu ID : 1 (0x1)
Format : AAC
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Delay relative to video : 9 ms
Menu
Menu ID : 1 (0x1)
http://www.mediafire.com/file/ofz36gcfvv7fbil/sample2.mkv
Sample 3
General
Complete name : R:\samples\nugi.mkv
Format : MPEG-TS
File size : 163 MiB
Duration : 6 min 59 s
Overall bit rate : 3 254 kb/s
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L3.1
Codec ID : 27
Height : 720 pixels
Frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : AAC
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Delay relative to video : 6 ms
Menu
Menu ID : 1 (0x1)
http://www.mediafire.com/file/4kxx8ace6kc6sxy/sample3.mkv
Sample 4
General
Complete name : R:\samples\benny.mkv
Format : MPEG-TS
File size : 199 MiB
Duration : 7 min 30 s
Overall bit rate : 3 711 kb/s
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.1
Format settings, GOP : M=4, N=60
Codec ID : 27
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 8 bits
Color primaries : BT.709
Transfer characteristics : sYCC
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AAC
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Menu
Menu ID : 1 (0x1)
http://www.mediafire.com/file/4hrh2q83nfb94wc/sample4.mkv
Hope it helps !
