New 4k + box, installed no problems, setup Synology NAS, no problems, watched all movie file types, no problems, then all of a sudden I cant watch .mkv files (HD). They just won’t play any more. Tried 720k HD .MP4 files, they play ok.
The box did do an auto update yesterday, but the files still played last night, unless the box did an update without me being there in the early hours?
reproduce the issue
Wow ! that was hard, but got it eventually Link to logs
Also, is there a soft reboot option as i cant find this anywhere ?
It might help you find the problem if I tell you the Video file is “Longmire”. the file name is .265 but it is not in that format.
I would prefer to do a factory reset, obviously thats why i cant do what you want me to do, because I am not seeing what you expect me to see.
Also, I need stuff to be as it should before I start spending time setting it all up.
Thanks for your help guys, Ill do just that !
