Recently Poland has moved from DVB-T to DVB-T2 standard using HEVC codec. Now any video from new channels is stuttering. Audio is OK. The same applies to recordings. But the recordings on another device (laptop) play well. So it seems to be a decoding issue (no hardware acceleration).
My device is Vero 4K+. Tvheadend is installed on a separate server with a PCIe TV tuner (TBS 6281SE). The same problem is observed when using the OSMC TV dongle, no matter if plugged into Vero 4K+ or the server.
Complete name : TV_sample_good.ts
Format : MPEG-TS
File size : 4.70 MiB
Duration : 9 s 165 ms
Overall bit rate : 4 277 kb/s
Original network name : Astra Satellite Network 19,2'E
Video
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main@L4.1@Main
Codec ID : 36
Duration : 9 s 400 ms
Bit rate : 3 839 kb/s
Maximum bit rate : 9 000 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.037
Stream size : 4.30 MiB (91%)
Language : Polish
Color range : Limited```
I might have found fix for this. At least it is currently working for me. Go to Adapter settings in the TVH server and check “force old status” on demodulator you are using. Once checked, I can no more see “continuity counter error” and TV stream is smooth with no lagging.
The SNR and signal strength are no longer displayed, but the main function of DVB-T2/C tuner is currently working fine.
