Hi. It is normal that /opt/retrosmc is the root as this is a chroot environment to prevent damage to the main system.
You should mount or bind the hdd to some place in /opt/reteosmc to make it accessible to ES.
I just installed OSMC on a clean SD card and tried to run the RetroPie Setup script and I am still receiving lots of errors regarding SDL packages.
thatâs not much info for me to go on - there are logfiles in the logs folder. It does show some dependency problems when first installing - it does dpkg -i and the apt-get -f install to correct dependencies, so they might not actually be errors you are seeing.
Okay, I am feeling quite stupid. I canât seem to get the SNES emulator to show up. I have done emulation station up and running. I have also done the following:
rm -r RetroPie/roms/snes
ln -s /media/NAS/ROMs/snes RetroPie/roms/snes
This step I did because all my ROMs are on a NFS. However, nothing shows up in emulation station as far as a snes emulator. Is there some other step I am suppose to do? All my ROMs are *.smc.
EDIT:
I ended up doing
rm -rf /opt/retrosmc/home/pi/RetroPie/roms
ln -s /media/NAS/ROMs /opt/retrosmc/home/pi/RetroPie/roms
instead, but in the log I get the ~/RetroPie/roms/snes is not a folder, but
ll /opt/retrosmc/home/pi/RetroPie/roms/
total 316K
drwxrwxrwx 2 1024 users 36K Nov 29 12:01 atari2600
drwxrwxrwx 2 1024 users 64K Nov 29 12:02 genesis
drwxrwxrwx 2 1024 users 20K Nov 29 12:03 mame
drwxrwxrwx 2 1024 users 4.0K Nov 29 12:03 n64
drwxrwxrwx 2 1024 users 124K Nov 29 12:04 nes
drwxrwxrwx 2 1024 users 56K Nov 29 14:03 snes
Try a bind mount - ES may not like symlinks.
mount --bind /media/NAS/ROMs /opt/retrosmc/home/pi/RetroPie/roms
Worked thanks!
Hello. I updated OSMC today, the november update, and now i have no sound in the games. Help me please.
So now a âofficialâ RetroPie Setup Script can be done? Or it stills doesnât work? I tried few weeks ago but I had problems with ÂżSDL? package.
SDL2 should be sorted now (see above).
It can be installed, but we donât do any integration etc with OSMC. The actual RetroPie-Setup system should work if you exit to a terminal and manually run emulationstation etc. Consider it experimental.
Yeah, I now. I have in my current installation the first âretropie_in_osmcâ, that works without âchrootâ. @mcobit did an script that basically launch EmulationStation and closes Kodi (plus the installation, of course)
Thent it evolved to the current packaged system, but if I can install the retropie stup I can have an updated RetroPie system (and re-executing the script to update)
Sorry for my absence lately.
If the installation works now (Iâll test that today), Iâd love to go back to the direct installation and revise the old version to have the newer features. Not sure if the old scripts will work out of the box.
Thanks @exobuzz for fixing the installation. Another question: Is there a way to not install all the dev packages when doing a binary installation?
nope, but they donât use much space compared to all the binaries etc.
Are there plans to add the Retropie Addon to the store to make it more seamless than getting the script and running it?
Hello. I updated again OSMC today, with the new 2015.11-02 update, and i still have no sound in the games. Help me please.
The new kernel doesnât support loading of alsa drivers via modprobe. If you add dtparam=audio=on in to your config.txt sound works again in your game emulators (no need for modprobe). More details can be found in this thread: New update and squeezelite - #4 by sam_nazarko
Still not possible to install libsdl1.2.
Unresolved dependencies:
Still libts etc.
Sdl2.0 seems to install fine now though.
Aah thanks - same problem as with the dependencies as sdl2 - Iâll need to rebuild new binaries. Iâve been quite busy recent so have had little time to check everything with binaries on OSMC. While you wait you can fix sdl1 by building that from source
sudo ./retropie_packages.sh sdl1
Thanks for your support.
Iâll test as soon as itâs ready.
Edit: Building sdl from source worked.
Thanks. I have now updated the binaries also.
This doesnât actually work. Iâve tried binding my drive /media/usb/emu to /opt/retrosmc/home/pi/RetroPie/emu and when I look though it within the File Manager within ES it shows up blank, but if I SSH into it (which is the root file systemâs SSH server) it shows up as linking.
