I recall that we had this conversation in November.
The Vero 4K/4K+ can provide 0.5A per USB port as per USB 2.0 specs. This will not be sufficient to power a 3.5" drive, but usually suffices for 2.5" drives and should suffice for a USB thumb drive.
In future iterations of hardware where we implement USB3, we can provide 1.5A per port.
After a while i don’t have image from the Vero when switching to the correct HDMI port.
I have Denon receiver and a Sony tv connected with each other.
When i power down the Vero, it reboots and everything is oke.
Quick update from my set up, since setting the GUI on my 4K TV to 1080p I’ve yet to have this issue reoccur. I’ll report back if it happens again. Hope everyone else has some luck in getting this annoying bug sorted soon.
As I have said in my first posts while the “grab-logs -A” command" seemed to work for the first couple of days returning a https://paste.osmc.tv/abcdefgh address, when the problem occurs 5-6-7 days later, it once again returns the https://paste.osmc.tv/html_ response. It seems that due to the log file size (?) it fails if the debug stays on for a certain extended time.
So I am not able to provide a log file that includes the issue this way, unless it occurs within e.g. 48 hours.
What I can do now, since I am away, is to provide some logs that I have available from this period that the problem is present.
So, in what version did you reproduce the issue on an LG TV?
I am in version 19.3 with the latest December update and I still have the problem since August.
