To make things easier for me (and maybe you too) I turned my host into 192.168.1.120 temporarily and I changed all the boxes from random 103-105 to 114, 115 and 117, with the PI as 116 because I’m messing with that one right now and I’d rather screw up my Pi than my vero haha.
I also changed the Hanewin export accordingly.
showmount will be slightly different because they are all static leases temporarily.
The lease for the pi i’m currently working on will be 116
osmc@osmc:~$ showmount -e 192.168.1.120
Export list for 192.168.1.120:
/t/Shows 192.168.1.116,-readonly
/v/Movie 192.168.1.116,-readonly
/r/Anime 192.168.1.116,-readonly
/Films 192.168.1.116,-readonly
I replaced smb with nfs in auto.master.
I created a new file named /etc/auto.nfs.shares (didn’t exist) and added /mnt/Movies 192.168.1.116:/u:/Movies (116 is my pi ip, the PC is 120).
to debug what’s wrong. While this is running, it will appear to keep trying to mount. That’s normal. While automount is running, open another SSH connection and try:
ls -lah /mnt/<server1>/<share1>
again while watching the output from the automount command.
To exit if running automount, just do a CTRL-C. To restart the service once everything is working, either reboot or:
Ok based on your showmount output I can not see “U” being shared and also the : as I expected is removed.
So lets use v for testing. The line in auto.nfs.shares should be /mnt/Movie 192.168.1.120:/v/Movie
Thank you I tend to screw up anyway haha.
I changed the /etc/auto.nfs.shares to /mnt/Movies 192.168.1.120:/u:/Movies which is the host.
Ok but this is where I usually rope myself, /mnt/<server1>/<share1> in this case would that be /mnt/192.168.1.120:/u:/Movies ?
I have no idea what I’m doing when it comes to this.
120 is my host, 114-117 are my boxes and yes I changed the hanewin information accordingly
sudo systemctl status autofs
autofs.service - Automounts filesystems on demand
Loaded: loaded (/lib/systemd/system/autofs.service; enabled; vendor preset: e
Active: active (running) since Wed 2020-05-13 14:07:42 CEST; 11min ago
Process: 2925 ExecStart=/usr/sbin/automount $OPTIONS --pid-file /var/run/autof
Main PID: 2926 (automount)
CGroup: /system.slice/autofs.service
`-2926 /usr/sbin/automount --pid-file /var/run/autofs.pid
May 13 14:07:42 osmc- systemd[1]: Starting Automounts filesystems on dema
May 13 14:07:42 osmc-automount[2926]: do_mount_autofs_direct: failed to
May 13 14:07:42 osmc- systemd[1]: Started Automounts filesystems on deman
[17]+ Stopped sudo systemctl status autofs
osmc@osmc-:~$ ls /mnt/Movie
ls: cannot access ‘/mnt/Movie’: No such file or directory
osmc@osmc-:~$
in the second window
sudo automount -f -v -d
Starting automounter version 5.1.2, master map /etc/auto.master
using kernel protocol version 5.03
lookup_nss_read_master: reading master file /etc/auto.master
do_init: parse(sun): init gathered global options: (null)
lookup_read_master: lookup(file): read entry +dir:/etc/auto.master.d
lookup_nss_read_master: reading master dir /etc/auto.master.d
lookup(dir): dir map /etc/auto.master.d missing or not readable
lookup(file): failed to read included master map dir:/etc/auto.master.d
lookup_read_master: lookup(file): read entry +auto.master
lookup_nss_read_master: reading master files auto.master
lookup(file): failed to read included master map auto.master
lookup_read_master: lookup(file): read entry /-
master_do_mount: mounting /-
automount_path_to_fifo: fifo name /var/run/autofs.fifo--
lookup_nss_read_map: reading map file /etc/auto.nfs.shares
do_mount_autofs_direct: failed to create mount directory /mnt/Movie
st_ready: st_ready(): state = 0 path /-
st_expire: state 1 path /-
expire_proc: exp_proc = 1949299792 path /-
expire_cleanup: got thid 1949299792 path /- stat 0
expire_cleanup: sigchld: exp 1949299792 finished, switching from 2 to 1
st_ready: st_ready(): state = 2 path /-
