riker1
16 November 2021 17:42
1
running RPI3 and osmc version:
osmc@osmcNEU:~$ grep Kodi .kodi/temp/kodi.log | head -3
2021-11-16 17:52:33.866 T:404 INFO <general>: Starting Kodi (19.1). Platform: Linux ARM (Thumb) 32-bit
2021-11-16 17:52:33.866 T:404 INFO <general>: Using Release Kodi x32
2021-11-16 17:52:33.866 T:404 INFO <general>: Kodi compiled 2021-09-14 by GCC 8.3.0 for Linux ARM (Thumb) 32-bit version 5.10.22 (330262)
Strangwise hdmi audio is not working.
In config.txt I added some hdmi settings - should be like hdmi save - without success.
hdmi_drive=2
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
config_hdmi_boost=4
hdmi_group=2
hdmi_mode=4
disable_overscan=0
overscan_left=24
overscan_right=24
overscan_top=24
overscan_bottom=24
in dmesg it looks like hdmi is enabled
osmc@osmcNEU:~$ journalctl | grep snd_bcm2835
Feb 14 11:11:58 osmcNEU kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
2021-11-16 15:06:58.091 T:1913 INFO <general>: CAESinkALSA - Unable to open device "default" for playback
2021-11-16 15:06:58.104 T:1913 INFO <general>: No Devices found - retry: 4
anyone experienced similar topics?
Thanks a lot
Yes. @nimbleguardian did. but he got no video and neither did I. Did you get a picture?
I found just reverting the kernel fixes it.
sudo apt-get install rbp2-image-5.10.32-2-osmc --reinstall
riker1
16 November 2021 18:16
3
ok thanks, will check that.
It used to work before I did some updates…
but was not using it for awhile
riker1:
I did some updates
It seems you are on the staging repo (buster-devel) which is still in testing.
riker1
16 November 2021 18:45
5
ok, let me check the repo,
still not working after
riker1
16 November 2021 18:55
6
right
deb http://apt.osmc.tv buster main
deb http://apt.osmc.tv buster-devel main
so will delete the buster-devel.
Will check
riker1
16 November 2021 20:40
7
still note working
how to downgrade to 18.8?
which sources to be used?
You cannot downgrade from Kodi v19 to Kodi v18.x.
If you took a backup, you could reinstall an older version and update.
riker1
17 November 2021 09:10
10
ok thanks,
will check
is this only entry correct for osmc in sources?
running 19.1.0-17
still no audio device present
is there a way to get hdmi audio in kodi 19.x?
or should I use kodi 18 fresh install?
did several reboots
Please post some logs so we can check package versions.
riker1
17 November 2021 09:27
12
What’s the output of
aplay -l
aplay -L
You may have to
sudo apt-get update && sudo apt-get install alsa-utils
to get aplay.
riker1
17 November 2021 11:19
14
Had to install alsa
resultaplay: device_list:272: no soundcards found... osmc@osmcNEU:~$ aplay -L null Discard all samples (playback) or generate zero samples (capture)
Video is working, stange
So sound is totally borked. I can only suggest backup and reinstall.
riker1:
ok thanks, will do that.
No need to reinstall, your problem comes from here
#dtoverlay=vc4-kms-v3d,cma-512
#https://discourse.osmc.tv/t/howto-install-a-vnc-server-on-the-raspberry-pi-currently-not-working-on-the-pi-4/1517/472
dtoverlay=vc4-fkms-v3d,cma-512
The fkms seems not to provide any audio device.
You could try to add dtoverlay=audio=on
riker1
19 November 2021 08:21
19
You could try to add `dtoverlay=audio=on
thanks, did not try that ,
but this did the trick.
dtparam=audio=on
Thanks a lot for your help…!!!
perfect
riker1
19 November 2021 08:24
20
