No Audio with DTS-HD-HRA Movies
Is it possible that the new update screwed up something with the DTS-HD-HRA Audio?
I don’t get sound from any movie with this audio format. Normal DTS, DTS-HD-MA, True Hd, Atmos etc… works fine, only the HRA DTS Tracks not.
I bought a new AVR (Denon AVR-X1400H) so i am not sure if this is a problem with the Vero/Osmc or with the AVR.
Can somebody check this please?
Using passthrough?
yes of course, all other formats are working fine, also DTS-HD-MA and Dolby Atmos
Maybe this will help:
Kodi Log:
http://paste.osmc.io/taxigiruku.vhdl
Movie with DTS-HD-HRA:
http://paste.osmc.io/qaniruwaqo.rib
I may be missing something but I don’t see DTS-HD or DTS-HD-HRA in the Denon specs - only DTS-HD-MA
DTS-HD is the Core so if the decoder can DTS-HD-MA, it also can DTS-HD-HRA
Atmos also is only in the TrueHD core Steam and is not an seperate
To my knowledge DTS-HRA is a given, if DTS-HD MA is supported…
Right. And in Kodi you can only enable DTS-HD so all HD is included there i can’t enable DTS-HD-MA or HRA
I can’t see anything wrong in the logs. OSMC is just sending a raw signal through as expected. Does the movie play on other hardware?
So, did some digging into the manuals of @Painkiller88’s Denon AVR-X1400H and my Denon AVR-X4300H…
This is the page from the 1400’s manual listing all supported sound formats:
And this from my 4300’s manual:
So, Denon doesn’t list the formats under the specifications section of the respective AVR’s website (rather just calling them DTS-HD and Dolby Surround). But here, DTS-HD HI RES (what Denon calls it - it’s the same as DTS-HD HRA, I guess) is clearly supported by both models… :slight_smile:
Just looking on another thread, Sam recommends audio settings at 7.1 and Fixed when using passthrough.
Just did a short test with this test file: DTS-HD HRA test file
Here it’s working like a charm! Sound is working and my AVR is showing DTS-HD HI RES. :thinking:
BTW: Using 7.1 setting with best match. :wink:
Like @Chillbo said: No issue with DTS-HD HRA using 7.1, best match, pass-through and here a Sony STR-DN840. It’s displayed as DTS-HD HRA in my AVR’s display.
@Painkiller88 From your logs: … mkvmerge v5.8.0 … dated 2012 …
Could you try remux one of the problem video with actual MKVToolnix at https://mkvtoolnix.download/ ?
I’ve got the Denon AVR 2400H. DTS HRA is working fine here.
yes i can try but this movies all run before so if the played once i think the should do it every time
I was able to figure out, this is not an issue of the Denon AVR
I took one of my original discs with the DTS-HD-HRA Audio format and put it into my PS4, here all is working fine.
So it’s a issue with Kodi.
@sam_nazarko
Maybe you can have a look on it, would be great.
Isn’t this probably the same issue as here: Issue with DTS-HD and Vero 4k
Also Denon and some weird format playback issues with Vero 4k…
I have just played my first .mkv with DTS-HD HRA and found the audio to be very low and when I increased it a lot, what audio there was sounded distorted. Setting the Vero 4K Audio setting to Fixed, fixed it.
Thanks to grahamh & Wuschel_Wuschel for their comments & link to the thread of “Issue with DTS-HD and Vero4K”
Just updated to the jannuary update of osmc on vero4k.
no improvements for DTS-HRA. Still no sound on that files
As far as I know, there weren’t any improvements for this in the January update. The same for Denon and Atmos passthrough issues.
