New Thread…
In reference to this:
Can I re-initiate the database upgrade, which seems to have gone wrong, or do I have to re-image the SD card?
Thanks…
Here is the initial post:
This update seems to have nuked my entire library. I have checked that the sources are there. I have checked that the OSMC settings still contain my shared mysql database info, but all I get on the Movies or TV Shows menu is:
Your library is currently empty. In order to populate it with your personal media, enter "Files" section, add a media source and configure it. After the source has been added and indexed you will be able to browse your library.
Well, same thing a day later.
Can I somehow re-initiate the library upgrade? Or, FFS, DO I HAVE TO START AGAIN?
This happened last time there was a major version upgrade.
LAME.
