Just a problem with copying the backup tarball from a temporary file to its final location, nothing major so it should be fixed soon.
Yes. Hardware accelerated so should be fine on Pi1.
Fixed. Proper number is 450,000.
S
the DefaultHardDisk image problem still exists in RC3.
Will it be fixed to Final ?
Hi. If I’d like to have my app Lumus (still looking for a better name) included to your AppStore, would that be possible? What should I do? It’s a web similar to Sickbeard running in node.js.
Thanks for your great work, btw!
Hi! Congrats on reaching RC3, OSMC just keeps getting better
I just did a clean install and had only 1 problem so far. I installed Hyperion but it didn’t work.
After some googling, I found I had to enable SPI in config.txt (dtparam=spi=on).
In your blog you specifically mention SPI being enabled for Hyperion, so I guess this is a bug? Or did I do something wrong?
Well done! Will be updating tonight.
Send me a PM and I can help
Is the backup settings now a full backup of everything? ie in case of SD corruption or upgrading the sd card?
Update went smooth as butter here.
Thanks once again to Sam and the team for your wonderful work!
No need for a PM.
Hyperion is working OK now after enabling SPI.
Just wanted to let you know
Any infos on coming i.mx6 support ?
@sam_nazarko
Congrats on reaching this milestone, everything running quite smoothly on my end. One small question: you mention in the release note that the firmware has been updated to fix possible rpi2 card corruptions, however checking the dedicated thread (https://github.com/raspberrypi/firmware/issues/397), from what I understand in one of Dom’s latest comments, we need to have
dtoverlay=sdhost
added to config.txt to benefit from the alternative driver, which I don’t see in mine - do we need to add it there manually?
Furthermore, a couple of commits have been made to the kernel related to sdcard corruption (and possible overclocking), apparently after you captured it for RC3.
Is this something needed which you will fix shortly through a new kernel compilation?
Thanks again for everything!
Where do you prefer that we post to make app requests? I’d love to see Couchpotato and Sonarr/nzbdrone on that list.
I prefer pull requests, but you can chuck them in Feature Requests subforum
Have asked popcornmix (Dom) for advice, don’t think it’s necessary anymore
S
The update to RC3 is failing on my PI B+ OSMC install.
It says there are updates available, but if I reboot I just end up with a sad little face and then it boots back into Kodi with nothing having changed.
I’ve uploaded my logs here: http://paste.osmc.io/ixemudecox
Please let me know if there’s any other info I can provide to help debug this.
Cheers,
Dave
Looks like those fixes are in. If you do have any corruption issues, check your power supply, and if that’s OK, continue to report on the GH issue.
S
From your logs all I can see is apparently Kodi is crashing part way through the upgrade process, but there is nothing to indicate what the cause might be. It could potentially be a bug in Kodi or the OSMC settings updater, both of which have updates waiting to apply, so may fix the problem if they could update ![]()
So I would suggest that this time around you manually update via SSH by doing the following:
sudo apt-get update && sudo apt-get dist-upgrade
reboot
Don’t worry when the screen goes blank during this process. Let us know if that works. If any errors occur please copy and paste them here.
Assuming it does update ok this way, keep an eye on it next time you try to update from OSMC settings and let us know if you have the same problem again.
Please don’t use the release thread for support requests and log links. That is not it’s purpose. Create an appropriately titled thread in the appropriate sub-forum for support requests.
Sorry ActionA, will make a new thread next time.
DBMandrake - I got an error on the first attempt, but followed the instructions and it now seems to be up and running on the new verison. Log of my SSH session here if you want to see the details: http://paste.osmc.io/ovunegabef
I’ll let you know if I have any problems with the next release.
Many Thanks,
Dave
