This seems to either have been fixed or was a freak one off.Left over night and was working fine. Multiple reboots and its still working.
I rebooted the Pi (via menu in Kodi), went to networking and all that was showing was Wired
Pulled the power and rebooted and same again, only wired. Not sure I can reproduce this error again?
There doesn’t seem to be this option under any of the menus, or does this need to be done via ssh?
Long time XBMC user, first time OSMC user here.
Install went very smoothly & was up and running in no time on new RPi2.
Got to iron out some issues with remote button mapping (not having any luck with Keymap Editor addon)
Great job guys!!
Well done on the rc. Runs great, setup was smooth. Still looking for samba shares though? Need to access usb hard drive connected to the pi from desktop windows pc.
Just an update, did a fresh install on another raspberry pi 2 and this didn’t happen. When going to networking only wired showed up.
Did have the issue with the return button on the MY OSMC app again, had to press it a few times to get any response but after that it seems to work. Tricky one to reproduce though to get a log. Will keep trying
Perhaps the method you’re trying isn’t the best to get results.
I find that looking for it under networks is a chancy business - you do better to do
Start|Run and then put the equivalent of \192.168.0.5 in the Open box (using the appropriate IP address), and hitting OK.
If that doesn’t work, then there is something else wrong
Derek
I have found it but now im having issues getting the /etc/samba/smb.conf configured right. No matter what changes i make i cannot gain access to the folders but i can now see them, and i would like it to be not password protected.
No OSMC updates have been released in the last few days for Pi 1 or Pi 2 that I’m aware of.
They may be Raspbian/Debian updates, but the built in update module in OSMC settings will not normally show those if no OSMC updates are available. (However if you update from the command line you will get them regardless)
