I keep loosing wireless connection to OSMC on my Pi 3… Sometimes, when I try to access the device with SSH or SFTP, the connection just times out. This usually happens after longer inactivity.
I’m running latest OSMC release, installed using March update. I’m using 2.5A power supply shipped with Pi 3. There’s no LAN connection, WiFi running via onboard module.
I have a feeling it might be related to wifi power management settings - iwconfig tells me those are ON. Has anyone experienced similar issues?
I have the same problem, it just keeps dropping the SSH connection every 2-5 min.
packet_write_wait: Connection to 172.16.132.200: Broken pipe
But I can then walk over and do a simple ping test and confirm that it’s still online, but can’t establish a connection SSH connection still won’t respond.
I have now run the cmd that you suggested and will get back to you with an update.
Interesting, I can not recall that I installed it (as I only have wired connection) and I have the wireless-tools installed. Maybe installed it before to test something for the forum.
@MarkusLangesudo apt-get install wireless-tools and you are done
Hi Guys, pi 3 wifi even with power management to off seems to not perform ok at all, it’s not possible to watch a descent size mkv from NAS with onboard wifi…
Any way to disable the onboard so we can use a usb wifi dongle??
(just adding a dongle seems to not work, it keeps using the bad onboard wifi)
