Is it possible with OSMC to disable Onboard Wifi for using an external 5ghz Wifi adapter ?
Both (internal and external) are identified by the system but they don’t mix well
Blacklisting wireless module ?
Thank’s for your help
Not sure whether there’s specifically some OSMC way to do so - obviously if there is (somewhere
) that would be the best option to use.
Otherwise, you might be right about your blacklisting suggestion; there’s a discussion here which you might find useful.
Hope that helps!
You might also find this thread useful as it seems you can turn it on and off using OSMC
Of course!
Go to: My OSMC -> Network -> Wireless -> Disable Adapter
Thank’s for your reply, THEM
Unfortunately you can’t disable just one interface (wlan0), in OSMC (it uses connman network management)
Blacklisting Broadcom drivers did the trick.
But i need wireless adapter (the 5ghz external one)
Any news? i got the same problem, want to use the 5GHZ adapter but cant because the onboard wifi is enabled and desn’t appear my WIFi
Well a quick and dirty solution is dtoverlay=sdhost in /boot/config.txt
