I cant wait to install OSMC in my Pi 4, I bought it when its out! Do you have any info of when the image roll out?
When itâs ready, weâll let you know.
Keep up the good work
Ill be waiting for news!
If I installed OSMC on RPI 3 and version for Rpi 4 will be out, will be necessary clean install (like for B+) or only update on RPI 3 and moving of SD card to RPI 4 will be enough?
Jan
A new installation will be needed.
Hi Sam,
I know there is a lot of work to prepare osmc distribution for RPI4, but do you have any approximate information? December 2019? March 2020?
I would like to use the equipment in some installations, but I am not sure whether to expect support within this period.
When itâs ready; but before December 2019 certainly.
Fast playback (2x, 4x, 16x) works very bad with the Pi3 - the image stops partially and then skips a few seconds. Is this problem fixed when using the Pi4?
No one knows, osmc isnât available for the Pi4.
Why would anyone assume it is if it wasnât announced yet and itâs not on the download page.
Dunno, ask @Ernesto
I would hazard the guess that @Ernesto is hoping form some informed speculation on the performance.
However being uninformed doesnât stop me from speculating
The Pi4 does have improved network specs (gigabit Ethernet) so fast-forwarding performance might be better assuming that decoding isnât a bottle neck for this particular task. I always assumed it was network bandwidth that would be limiting in forwarding through HD movies from a remote (NAS) location, but I could be wrong.
Hi, that with the network connection sounds very reasonable and gives hope. It may well be that the problem is due to this.
Seems more like a problem on your end, i have a have 2 pis, 3 and 3B not a single one of them has that issue. Mounted via system mount (smb) i only had this issue when i used the kodi intern mounting system.
People in general have little to no understanding of networking and tend to blame the software for their problems.
If using SMB, try using an FTP server instead and see if the superior speed of FTP helps to resolve the issue.
Pretty sure nfs is recommended above everything else.
For me, FTP was faster than NFS (not by a whole lot, but faster nonetheless), and max speed is what I needed. Iâm using powerline ethernet.
Speed wise I think theyâre quite similar, I moved away from power line adapters this year, put the work in and pulled cat6e wherever I needed itâŚit was a fair bit of work but getting close to 1gbs across my entire network has made the effort worthwhile.
Is there any progress on an ETA off an OSMC build for the RPI4 ?
Tia
Leurb
