It only seems to happen on the 1080p and 720 high bitrate files. The rest never gives problems.
https://paste.osmc.tv/piduhojiqu
The file plays well, CPU-KODI is under 30% (or so) and suddenly the movie freezes.
I use SMB now but i did try it via NFS and exactly the same happens.
I tried adjusting buffer/ turning of the hardware rendering options but no difference.
Ill add the Media info output under here, hope this is ok, hope you see something because i have ran out of options
General
Unique ID : 198745317271589993566312564830671682513 (0x9584F4AE42C7A44C94F442879C2F3BD1)
Complete name : Audition.1999.720p\Audition.1999.720p.mkv
Format : Matroska
Format version : Version 2
File size : 6.56 GiB
Duration : 1 h 55 min
Overall bit rate : 8 123 kb/s
Encoded date : UTC 2009-09-30 21:51:20
Writing application : mkvmerge v2.9.8 (‘C’est le bon’) built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, RefFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 6 613 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.299
Stream size : 5.21 GiB (79%)
Writing library : x264 core 75 r1259 dd026f2
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=6613 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : Japanese
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 5 channels
Channel positions : Front: L C R, Side: L R
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.22 GiB (19%)
Language : Japanese
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
