ok, finally it’s working. first, editing the config.txt is much more reliable than blacklisting. Second, i needed to change my 5ghz wifi channel (after using an analyzer) to a much higher channel 153 from 44. much less occupied. now i am able to access everything , even after a few reboots.
it must be that precise location in the house, because nothing else had an issue on that 5ghz wifi channel. Crossing my fingers that it lasts. I expect it to, because changing the channel seemed to immediately get it to connect
on both 2.4 ghz and 5 ghz, i had a problem where every few seconds, when running an iperf test, i would get 0mb transfer. i assumed this was due to background scanning so i disabled it.
disabling background scanning solved the issue for the 2.4 ghz side. When i do iperf, every second i get the expected transfer rate. on 5ghz however, still every few seconds i get a 0mb transfer rate, as if the connection is dropping out for a few seconds.
all computers are in same room:
I tried VHT160, changed channel, no way to get my 5ghz working. no hardware issue, the key has been tested on windows PC
I bought 4 usb adaptaters for all my rpi3… 2 days wasted on this… for something noted ‘ready to use’ on the webshop.
My config is
router internet box > netgear x6 (repeater bridge) dd-wrt
windows test :
ok conenction direct on router (2.4)
ok connection on dd-wrt (2.4 and 5)
osmc pi3 test:
ok connection direct on router (2.4)
NOK connection on dd-wrt (2.4 and 5) dhcp or static IP
wireless and country code worked.
Successfull with open wifi network, now I have to find settings for wpa aes key coz if I activate it I can’t connect
In comparison with my laptop internal ac wifi or iphone 7, the transfer rate is not huge but I guess for the price I’m satisfied and and can stream 1080p
In the mt7610u_sta.dat only change CountryCode and wireless mode, leave rest as defaults. Now set up the connection via Myosmc including the wpa2 password.
yes I tried. But I think the connection wifi is done, maybe more about gateway or dns issue… coz when randomly working status internet conection is ok. but main time statut connection is no internet
