This will be lengthy. Sorry, but I feel I need to be explicit in explaining my testing steps, so the 4K video files do not get the blame.
When I say:
Warm Boot, it means that I have chosen Power/Reboot.
Cold Boot, it means that I have chosen Power/Power Off System. I then turn the power off at the wall for 30 seconds.
I will use the exact same 4K TV videos (five episodes of different series) and eight 4K movies in my testing on both the Vero 4K & 4K+. The videos are on different external HDDs and a USB stick.
I will first play off a USB stick in the white port & then plug in a powered hub and play the stick & other HDDs from the hub. I will use this configuration after each Warm & Cold boot on both Vero’s.
Vero 4K+
SATURDAY 01/01/2022.
Installed 2021-12.1 from SD card. Now on Linux 4.9.113-60 -osmc Kodi 19.3
In case it may be thought I have configured the setup wrong, this is what I did (some
things left at default):
Setting Level: Expert.
System/Display defaulted to 1920×1080p (2D). Refresh Rate 59.94. Whitelist is not active.
System Audio Output/ changed to HDMI. Channels left at 2.0
Output Configuration/ left at Best Match.
Audio Passthrough/ I allowed everything except AC3 transcoding.
Settings/Interface/Skin/Configure Skin/Show Date Above System Time.
Settings/Regional/Unit Formats/Regional Default Format/UK (12hr).
Timezone Country/New Zealand.
Speed Unit/ changed to Km/h.
Settings/Player/Videos/Playback/Default at Start/Stop.
Display 4:3 Videos As/ Default at Normal.
HDR Processing is at default: Normal.
Media/General/ticked Allow File Renaming And Deletion.
My OSMC/Updates/Schedule/changed from Daily to Never.
After installing and configuring the above, I did NOT Warm or Cold boot.
All the 4K videos on the USB stick & external HDDs played OK.
Warm Boot:
USB stick only connected. The 4K videos played OK.
Connected the powered hub and played the USB stick 4K videos again. Played OK.
Played a 4K video from an HDD, it played OK.
Backed out of the video and got an Orange screen. No response to the remote control.
Had to power off at the wall. (I suppose this may be considered a Cold Boot?).
Played all the 4K videos from the USB stick & HDDs.
All the 4K videos played OK.
No more Orange screens, even when backing out from the file it happened with previously.
Warm Boot:
All 4K videos played OK.
Warm Boot:
Cold Boot:
All 4K videos played BAD. Same rhythmic freezing as previously reported and shown in my submitted photos/phone videos.
Warm Boot:
Cold Boot:
Cold Boot:
Warm Boot:
Warm Boot:
Warm Boot:
Cold Boot:
Cold Boot:
Cold Boot:
Warm Boot:
Cold Boot:
Powered off, went to bed.
Vero 4K+
SUNDAY 02/01/2022
Turned on at the wall.
Warm Boot:
Cold Boot:
Warm Boot:
Cold Boot:
Warm Boot:
Turned it off.
Testing My Other Vero, the 4K.
Was on 2021-11.1 Linux 4.9.113-55-osmc. Kodi 19.3
All 1080p & 4K videos played OK.
Configured it exactly the same as I did to the Vero 4K+
Warm Boot:
Cold Boot:
Warm Boot:
Turned off.
Both Vero’s play 1080p & 3D OK.
Some of the 4K movies that I used for this testing, I have had for a few years and I have viewed them more than once. They have always played OK before on the various versions of OSMC that the Vero’s updated too. I have had the 4K since June 2017 & the 4K+ since December 2020.
The rhythmic freezing only started after I updated to Kodi 19.3 … and ONLY on the 4K+
I understand that you can get a bad 4K video file. The number of 4K videos I have tested with, that have always played OK on both Vero’s previously, surely points to a problem between Kodi 19.3 & the 4K+
The 4K plays all my 4K video files faultlessly.
With both Vero’s now on Kodi 19.3, why is it that only the 4K+ has the playback problem with the same 4K videos?
