Hi team…so did some light dusting behind Vero 4k etc and SPDIF fell out…tried to put back in and just no positive click…tried somes tunes and doesn’t work…if I push the cable in hard it sometimes works but as soon as I release it , it does not work…just seems strange…it can come out with the loosest of pulls…I can try another cable tomorrow but don’t remember when I set the sound up that there was no positive click for the SPDIF…seem to remember it all just fitted snugly in…
Cable used was generic Optical SPDIF one…nothing special…just when I look into the hole on the Vero 4k I can see in the optical out bit that there is a metal like spring…I assume this is to keep the cable in…I hope it is the cable that has failed and not the other way around…just can’t see what the problem is…been working well for 6 months…
I don’t remember any flap neither – though it seems there was one, briefly. There’s @Chillbo recipe how to fix that yourself - I intend to do it. Currently I get sound as long as I carefully slide it into the socket and don’t touch the 4k.
Think I have a handle on the process…will have to tackle tomorrow. …
In terms of best quality…would the tv optical out to dac/stereo be good/the same?..any other way of getting sound out from vero 4k? Thanks m
Ok…so I have hdmi to tv and then i could get 3m optical cable to dac then into amp…
If I didn’t use the vero’so own Opt out then surely this is the only option…
Thanks Sam…thing is I have probably only fiddled with the back about 4 times during set up and now it’s broken. I have got it to work though by pushing it in and holding in position with some tape…but it is a bit Heath Robinson.
