My network shares are still not accessible after the october and november updates.
To be sure I did a fresh install (june image) on my Vero4k+.
Only thing I’ve changed in the fresh install is de min and max SMB client to v3.
After setting up the network share, with IP address as a server and a username + password the share works just fine
After this I did the OSMC update to the november build (Kodi 18.9) and changed nothing to the settings.
When opening my network share I get the message “ operation not permitted”
Yes it worked for a couple of weeks and then it suddenly stopped working. Could be that another update was installed. So to be sure there was nothing else involved I did a fresh installation of the june/october/nov builds.
That was the problem! Didn’t know this password could expire.
I’ve set it to " never expire" and this solved the problem.
This was probably also the fix in the earlier problem I’ve had.
